how to implement Cmu changing with mesh coordinates |
December 3, 2013, 05:21 |
zdong
Rep Power: 15 |
I need to make the constant Cmu in kEpsilon turbulence model in OpenFOAM-2.2.1 to change with height like this :
Cmu=pow(uStar,4)/(D1*ln(z+z0)+D2) in which uStar D1 D2 z0 are predefined constants,and z is the z-coordinate of the mesh. I have tried it like this in the *.C file of myKEpsilon model: Code:
Cmu_ ( IOobject ( "Cmu", runTime_timeName(), mesh_, IOobject::MUST_READ, IOobject::AUTO_WRITHE ), mesh_ ) My problem are : 1) From certain reference paper, the ignoring of the BC typeName in the parameters list of IOobject means the Boundary condition of the defined geometricField will be then calculated, so am I ritht to define the Cmu field like this or there is a better solution or even the Cmu could not defined as volScalarField at all? 2) If the above definition for Cmu field is appropriate, then how can i initialize the Cmu nonuniformly in the 0/Cmu file, as it's associated with the mesh coordinates, and for what the boundary conditions should applied , the Dirichlet BC ? Thanks for your reply , and the attached file is the source and head files of myKEpsilon. best regards . Dong |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
