multiphaseEulerFoam: method iter() and calculation of phase fractions
Old   December 2, 2013, 09:22
Default multiphaseEulerFoam: method iter() and calculation of phase fractions
maybee is on a distinguished road
hi,
I have a few questions about the multiphaseEuler solver:
1. Within the main method of the solvers .C file there is the file "createFields.H" included. Within this file can be found
forAllIter(PtrDictionary<phaseModel>, fluid.phases(), iter)
        phaseModel& phase = iter();
        const volScalarField& alpha = phase;
        U += alpha*phase.U();
        phi += fvc::interpolate(alpha)*phase.phi();
with the method iter():
inline Foam::label Foam::cloudSolution::iter() const   //Return const access to the current
        //cloud iteration.
return iter_;   //label iter_;  //- Current cloud iteration
I assume that alpha is one phase fraction, right?
Furthermore alpha is a reference to iter() which means a reference to the variable iter_ . But, what is iter_ exactly?
2. After the solvers loop is started later in the main method with "while (runTime.run())" at which point are the phase fractions calculated and saved?
greetings
maybee
maybee is offline   Reply With Quote
Old   July 22, 2020, 09:20
Elol
Elol is on a distinguished road
Hi Foamers,
I have almost the same question as I don't fully unterstand what is the iter(). I have the following piece of code which I am trying to understand
void Foam::multiphaseDriftMixture::calcAlphas()
    alphas_ == 0.0;
    forAllIter(PtrDictionary<phaseDrift>, phasesk_, iter) //Iterate across all elments in the Phasesk_ (transport prorties) which is type from PtrDictionary<phaseDrift>
        alphas_ += iter(); // alphas_ = alphas_ + iter()
what i understand that the for loop is looping on the Container type (phase drift dictionary) and phasesk contatiner and iter. alphas_ starts with 0.0 + iter()
what is the iter()?
Elol is offline   Reply With Quote
