Viscosity model - Compressible flow
Old   November 19, 2013, 12:50
Default Viscosity model - Compressible flow
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hi everyone,
I have some problems developping a viscosity model in OpenFoam-2.2.2. This model is quite simple : for a given value of the strain rate, I have a viscosity value.
So this is what I'm trying :
1) copy paste "src/thermophysicalModels/specie/transport/sutherland" to "src/thermophysicalModels/specie/transport/myTotalTransport"
2) renamed everything, and cleaned the constructors and operators.
3) created a createFields.H file :
#include "interpolationTable.H"
interpolationTable<scalar> timeSeriesViscosity
"constant/viscosity.dat"
4) I included the createFields.H file in the others .C and .H files.
5) Modified the function mu in the file "~I.H"
template<class Thermo>
inline Foam::scalar Foam::myTotalTransport<Thermo>::mu
)const
volScalarField sr = strainRate();
return timeSeriesViscosity(sr.value());
6) Modify the thermoPhysicsTypes.C to add my new model.
7) Compiled : these are the errors
- strainRate : working with incompressible models, but not here
error : there are no arguments to 'strainRate' that depend on a template parameter, so a declaration of 'strainRate' must be available
- interpolationTable : I have included "interpolationTable.H", so I don't understand this one :
error: 'interpolationTable' does not name a type
Any help would be greatly appreciated.
Aurelien Thinat is offline   Reply With Quote
Old   November 20, 2013, 05:33
Aurelien Thinat
I'll start fixing the problem with the strainRate first. It seems it's not defined for compressible flow : as far as I understand the code, there is no volScalarFields defined at this level.
So I need to compute manually the value of the strain rate at the current cell. How can I get an access to
- the velocity ?
- symm() ?
- fvc::grad() ?
Old   November 21, 2013, 05:14
Aurelien Thinat
Hello everyone,
I did it with incompressible fluids. Then I compiled another thermo model for compressible fluids.
And now I'm stuck with the selection table. Where is the file I need to modify to enable the choice ?
heRhoThermo -
pureMixture -
myTransportModel -
hconst -
perfectFluid -
specie -
sensibleInternalEnergy
I tried to modify the file /src/thermoPhysicalModels/specie/include/thermoPhysicsTypes.H, but there is no mention of perfectFluid in this file, I guess it's the wrong place.
Thank you.
EDIT : It seems it's the file rhoTermos.C.
Old   March 6, 2018, 08:08
Alberto
malv83 is on a distinguished road
Originally Posted by Aurelien Thinat View Post
Hello everyone,
heRhoThermo -
pureMixture -
myTransportModel -
hconst -
perfectFluid -
specie -
Thank you.
Hello Aurelien,
Could you share how did you include the strain rate for compressible models?... It seems like an unanswered question everywhere.
Thank you in advanced
malv83 is offline   Reply With Quote
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Viscosity ratio in gamma-theta transition model based on k-w sst turb model Qiaol618 Main CFD Forum 8 June 9, 2012 07:43
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 04:42
compressible flow maria teresa FLUENT 1 September 7, 2007 17:58
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 05:22
