Questions regarding mappedVelocityFluxFidedValue boundary condition |
November 14, 2013, 23:05 |
Rep Power: 14 |
Hi Foamers,
I have a question regarding the implementation of mappedVelocityFluxFixedValueFvPatchField::updateCo effs(). The code is listed below: Code:
162 void Foam::mappedVelocityFluxFixedValueFvPatchField::updateCoeffs() 163 { 164 if (updated()) 165 { 166 return; 167 } 168 169 // Since we're inside initEvaluate/evaluate there might be processor 170 // comms underway. Change the tag we use. 171 int oldTag = UPstream::msgType(); 172 UPstream::msgType() = oldTag+1; 173 174 // Get the mappedPatchBase 175 const mappedPatchBase& mpp = refCast<const mappedPatchBase> 176 ( 177 mappedVelocityFluxFixedValueFvPatchField::patch().patch() 178 ); 179 const fvMesh& nbrMesh = refCast<const fvMesh>(mpp.sampleMesh()); 180 const word& fieldName = dimensionedInternalField().name(); 181 const volVectorField& UField = 182 nbrMesh.lookupObject<volVectorField>(fieldName); 183 184 surfaceScalarField& phiField = const_cast<surfaceScalarField&> 185 ( 186 nbrMesh.lookupObject<surfaceScalarField>(phiName_) 187 ); 188 189 vectorField newUValues; 190 scalarField newPhiValues; 191 192 switch (mpp.mode()) 193 { 194 case mappedPolyPatch::NEARESTFACE: 195 { 196 vectorField allUValues(nbrMesh.nFaces(), vector::zero); 197 scalarField allPhiValues(nbrMesh.nFaces(), 0.0); 198 199 forAll(UField.boundaryField(), patchI) 200 { 201 const fvPatchVectorField& Upf = UField.boundaryField()[patchI]; 202 const scalarField& phipf = phiField.boundaryField()[patchI]; 203 204 label faceStart = Upf.patch().start(); 205 206 forAll(Upf, faceI) 207 { 208 allUValues[faceStart + faceI] = Upf[faceI]; 209 allPhiValues[faceStart + faceI] = phipf[faceI]; 210 } 211 } 212 213 mpp.distribute(allUValues); 214 newUValues.transfer(allUValues); 215 216 mpp.distribute(allPhiValues); 217 newPhiValues.transfer(allPhiValues); 218 219 break; 220 } 221 case mappedPolyPatch::NEARESTPATCHFACE: 222 case mappedPolyPatch::NEARESTPATCHFACEAMI: 223 { 224 const label nbrPatchID = 225 nbrMesh.boundaryMesh().findPatchID(mpp.samplePatch()); 226 227 newUValues = UField.boundaryField()[nbrPatchID]; 228 mpp.distribute(newUValues); 229 230 newPhiValues = phiField.boundaryField()[nbrPatchID]; 231 mpp.distribute(newPhiValues); 232 233 break; 234 } 235 default: 236 { 237 FatalErrorIn 238 ( 239 "mappedVelocityFluxFixedValueFvPatchField::" 240 "updateCoeffs()" 241 ) << "patch can only be used in NEARESTPATCHFACE, " 242 << "NEARESTPATCHFACEAMI or NEARESTFACE mode" << nl 243 << abort(FatalError); 244 } 245 } 246 247 operator==(newUValues); 248 phiField.boundaryField()[patch().index()] == newPhiValues; 249 250 // Restore tag 251 UPstream::msgType() = oldTag; 252 253 fixedValueFvPatchVectorField::updateCoeffs(); 254 } Code:
199 forAll(UField.boundaryField(), patchI) 200 { 201 const fvPatchVectorField& Upf = UField.boundaryField()[patchI]; And Upf here is the boundary field (U field at boundary patches) rather than the U field of the sampled, internal patch (given by the keyword "offset" in file constant/polyMesh/boundary). But later Code:
206 forAll(Upf, faceI) 207 { 208 allUValues[faceStart + faceI] = Upf[faceI]; 209 allPhiValues[faceStart + faceI] = phipf[faceI]; 210 } Code:
174 // Get the mappedPatchBase 175 const mappedPatchBase& mpp = refCast<const mappedPatchBase> 176 ( 177 mappedVelocityFluxFixedValueFvPatchField::patch().patch() 178 ); Can anybody give me a hint? Sorry if this is a silly question. I am now trying to implement a new boundary condition based on this one, but still have some problems. When using pisoFoam, this updateCoeffs() will be called three times during each time step. Is this right? If I want to keep a running average of the sampled patch, should I do it during each call or do it only once during one time step? If latter, how can I do it? By comparing curTimeIndex with db().time().timeIndex()? |
boundary conditions, programming |
Opening Boundary Condition | andreachan | Main CFD Forum | 11 | March 19, 2013 17:46 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
Boundary Condition Questions | malfonso1286 | STAR-CCM+ | 1 | September 12, 2010 19:07 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 01:55 |
