October 29, 2013, 05:45 |
renumberMesh in openfoam
Yu CAO
Rep Power: 13 |
Hi
Does anyone know that the function renumberMesh would change the value of points and why? I run "renumberMesh -orderpoints" and found out that the value of points had been changed. I was so surprised about this. Thanks Yu |
November 3, 2013, 14:48 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Yu,
Could you please tell which version you are using? I have tried looking in 2.2.1 and 1.6-ext and none of these recognise the "-orderpoints" option. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
November 3, 2013, 16:26 |
#3 | |
Yu CAO
Rep Power: 13 |
Thank you for your reply. the version I used is 2.1.0. This option did not exits in 1.6-ext, and I did not know if it exists in 2.2.1. Regards Yu |
November 13, 2013, 16:24 |
Rep Power: 37 |
Sorry for the late reply. I have just checked, and the method seems to be changing the point ordering, such that all internal points are first in the pointField followed by all the points on the boundaries. The option, however, has not caused any problems in terms of mesh quality or improper correction of the indexing of the faces. But you experienced problems? Kind regards, Niels
November 13, 2013, 16:58 |
#5 | |
Yu CAO
Rep Power: 13 |
Thank you for your reply.I found out that the value of points had been changed after this option. I was so surprised about this. Regards Yu |
[mesh manipulation] renumberMesh in openfoam | cctv | OpenFOAM Meshing & Mesh Conversion | 1 | December 11, 2013 06:01 |
[mesh manipulation] refineMesh in openfoam | cctv | OpenFOAM Meshing & Mesh Conversion | 0 | October 22, 2013 06:48 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 08:18 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 08:14 |
