How to get access to a certain boundary?
Old   October 28, 2013, 22:09
Question How to get access to a certain boundary?
Ke Li
TankTinyPig is on a distinguished road
Hello!
Good day to everyone!
I'm a beginner of operating OpenFOAM codes, I have some trouble in searching a certain class instance and accessing its memberfunctions. Details are listed below:
I'm going to simulate two solid body in fluid fields. One can move freely and the other must move according to the movement of the first one. So I use two boundary field type to abtain this goal. One is "sixDofSolidMotionDisplacement" named "wing" and the other is "angularOscillatingDisplacment" named "plate", and they are set in file "0/pointDisplacement".
Now, in order to make the forced move object rotate according to the movement of the first one, I have to modify the "angularOscillatingDisplacment" class to make "plate" be able to get information of the class instance "wing". Now it's time to ask the question:
I know the name is "wing", how can I find this class instance?
Thank you all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TankTinyPig is offline   Reply With Quote
Old   October 31, 2013, 06:03
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Originally Posted by TankTinyPig View Post
Hello!
 label wingPatchID = mesh.boundary().findPatchID("wing");
 //for any field S of type T:
 fvPatchField<T>& pwing = S.boundaryField()[wingPatchID];
Have a look at the OpenFOAM source code documentation:
http://foam.sourceforge.net/docs/cpp/a00741.html
http://foam.sourceforge.net/docs/cpp/a01665.html
mkraposhin is offline   Reply With Quote
Old   October 31, 2013, 21:43
Ke Li
oh! It works out! Thank you very much!!!!!!
boundary, dynamic mesh, pimpledymfoam
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
access to a property in a boundary condition using UDF Negin_Salehi Fluent UDF and Scheme Programming 3 November 16, 2012 17:11
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
