October 11, 2013, 12:59 |
FOAM FATAL ERROR: bad size
Rep Power: 15 |
Hello foamers,
I'm playing around with MRconjugateHeatFoam, which is a conjugate heat transfer solver. I was able to modify this solver in a way, such that it can handle two phase flow. Unfortunately after some time steps (depends on the memory), I'll get errors like this: Code:
--> FOAM FATAL ERROR: bad size -1317939304 From function List<T>::List(const label size) in file /opt/openfoam220/src/OpenFOAM/lnInclude/List.C at line 49. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at /opt/openfoam220/src/OSspecific/POSIX/printStack.C:221 #1 Foam::error::abort() at /opt/openfoam220/src/OpenFOAM/lnInclude/error.C:249 #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at /opt/openfoam220/src/OpenFOAM/lnInclude/errorManip.H:85 #3 Foam::List<double>::List(int) at /opt/openfoam220/src/OpenFOAM/lnInclude/List.C:54 #4 Foam::Field<double>::Field(int) at /opt/openfoam220/src/OpenFOAM/lnInclude/Field.C:50 #5 Foam::tmp<Foam::Field<double> > Foam::mag<double>(Foam::UList<double> const&) at /opt/openfoam220/src/OpenFOAM/lnInclude/FieldFunctions.C:180 #6 at ~/OpenFOAM/of-2.2.0/applications/solvers/CHTinterDyMFOAM/coupledFvPatchFields/regionCoupleHeatFlux/regionCoupleHeatFluxFvPatchScalarField.C:222 #7 at ~/OpenFOAM/of-2.2.0/applications/solvers/CHTinterDyMFOAM/convergenceCheck.H:112 #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/home/willy/OpenFOAM/of-2.2.0/platforms/linux64GccDPDebug/bin/CHTinterDyMFoam" Code:
const Foam::scalar& Foam::regionCoupleHeatFluxFvPatchScalarField::maxResidual() const { // Calculate interpolated patch flux const polyPatch& ownPatch = patch().patch(); const polyPatch& nbrPatch = coupleManager_.neighbourPatch().patch(); const fvPatchField<scalar>& Tnbr = coupleManager_.neighbourPatchField<scalar>(); patchToPatchInterpolation interpolator(nbrPatch, ownPatch); scalarField qNbr2own = interpolator.faceInterpolate ( refCast<const regionCoupleTemperatureFvPatchScalarField> (Tnbr).flux() ); // Lookup transport properties const dictionary& transportProperties = db().lookupObject<IOdictionary>("transportProperties"); dictionary phaseSolid(transportProperties.subDict("phaseSolid")); dimensionedScalar kS(phaseSolid.lookup("k")); // Calculate the maximum normalized residual const fvPatchScalarField& Town = *this; //Temperature of own face (Tsolid, if regionCoupleTemperature is set in solid bc) const scalarField& qOwn = kS.value()*Town.snGrad(); const scalar& residual = gMax ( mag(mag(qOwn) - mag(qNbr2own))/ max(min(gMax(mag(qOwn)),gMax(mag(qNbr2own))), SMALL) //line 222 ); return residual; } Code:
//- Return the patch flux Foam::tmp<Foam::scalarField> Foam::regionCoupleTemperatureFvPatchScalarField::flux() const { // Set up access to the thermaly conductivity field and mesh const volScalarField& k12 = db().lookupObject<volScalarField>("k12"); //Wird hier auch von runTime gelesen und nicht von dem gespeicherten Zeitordner??? //const fvMesh& mesh = patch().boundaryMesh().mesh(); //Get ID of local patch in T boundary file (fluid side) label patchID = patch().boundaryMesh().findPatchID(patch().name()); //Get the k-boundaryField with same patch ID (fluid side) const fvPatchScalarField& kF = k12.boundaryField()[patchID]; const fvPatchScalarField& T = *this; //Temperature of own face (Tfluid, if regionCoupleTemperature is set in fluid bc) return kF*T.snGrad(); //Fourier's law. } The relevant source files are attached. |
October 14, 2013, 10:05 |
Rep Power: 15 |
I could't solve the problem directly, but I was able to run the case without errors, when I'm using a static mesh instead of dynamicFvMesh.
April 6, 2016, 12:39 |
About the code
Emanuele
Rep Power: 12 |
Hi! could you give me please more information concerning the file createFields.H i,m also dealing with a similar problem MR solver + interFoam trying to couple them.
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 16:05 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 23:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
