how to decrease time step based on previous result in openfoam
Old   September 25, 2013, 06:35
Default how to decrease time step based on previous result in openfoam
Yu CAO
cctv is on a distinguished road
Hi
how to decrease time step based on previous result in openfoam? for example, at first, I set deltaT=0.1, and runed to 10, then I want to change deltaT to 0.01, and begin from time 10, what should I do? I changed the deltaT to 0.01 in system/controlDIC, but find it just ran 10 times 10.01,not from 10.01 to 10.10. Is that correct? What should I do?
Thank.
cctv is offline   Reply With Quote
Old   September 25, 2013, 07:31
Yu CAO
It seems because of time precision. I am wondering if there are any files except the uniform/time in the output folder would record time precision? I successfully change the deltaT in the same folder, but failed to do so by cp previous result from another folder. I am not sure the reason.
Old   September 26, 2013, 05:21
Joachim Herb
jherb is on a distinguished road
Please post your system/controlDict. The relevant parameters are startFrom, startTime, stopAt, endTime, deltaT, writeControl and writeInterval. Perhaps also adjustTimeStep.
jherb is offline   Reply With Quote
Old   September 26, 2013, 07:34
Yu CAO
startFrom latestTime;
startTime 0.0;
stopAt endTime;
endTime 2000.0;
deltaT 0.00001;
writeControl runTime;
writeInterval 10;
cycleWrite 1;
writeFormat ascii;
writeCompression uncompressed;
timeFormat general;
timePrecision 8;
Old   September 26, 2013, 18:17
Joachim Herb
I do not know what cycleWrite means. Otherwise you might want to start from the tutorials, e.g. simpleFoam/motorBike:
startTime 0.0;
stopAt          endTime;
endTime 10.1;
deltaT 0.01;
writeControl    timeStep;
writeInterval   1;
Old   September 27, 2013, 17:56
Yu CAO
startTime 0.0;
stopAt          endTime;
endTime 10.1;
deltaT 0.01;
writeInterval   1;
Have you tried before?
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 04:41
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
