Problems on implementing actuation disk on piso solver |
September 25, 2013, 01:36 |
Frank Yu
Rep Power: 15 |
Hi fellows,
I am tring to implement the actuation disk to the pisoFoam solver. Currently all I know about the way to do it is learned from the tutorial package “turbine siting”. However, i just want to implement it under a simple channel flow, and got the following problem on reading the disk properties. The modified piso solver is like following: Code:
#include "fvCFD.H" #include "singlePhaseTransportModel.H" #include "turbulenceModel.H" #include "IObasicSourceList.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" IObasicSourceList actuationDisks(mesh); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "readPISOControls.H" #include "CourantNo.H" // Pressure-velocity PISO corrector { // Momentum predictor fvVectorMatrix UEqn ( fvm::ddt(U.oldTime(), U) + fvm::div(phi, U) + turbulence->divDevReff(U) ); // Add resistance on the actuation disks actuationDisks.addSu(UEqn); UEqn.relax(); if (momentumPredictor) { solve(UEqn == -fvc::grad(p)); } // --- PISO loop .... and the “sourceProperties” file and “makeZones” file is the same as the one in tutorial (changed size and location). When I run the new piso solver on my case, I got the following message: Code:
--> FOAM FATAL IO ERROR: keyword type is undefined in dictionary "/home/frank/OpenFOAM/frank-2.0.0/run/case8/constant/sourcesProperties::disk1" file: /home/frank/OpenFOAM/frank-2.0.0/run/case8_ActuationDisk/cpiso/constant/sourcesProperties::disk1 from line 20 to line 33. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting Am I missing some settings in my case? I cross checked with the tutorial case but couldn't find one. Thanks a lot. Regards Frank |
September 28, 2013, 09:01 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Frank,
The message is somewhat clear about the problem: Quote:
In OpenFOAM 2.0, an example can be found at tutorials/incompressible/windSimpleFoam/turbineSiting/constant/sourcesProperties. In OpenFOAM 2.1, the example is at tutorials/incompressible/simpleFoam/turbineSiting/constant/sourcesProperties. In OpenFOAM 2.2, the example is at tutorials/incompressible/simpleFoam/turbineSiting/system/fvOptions. Best regards, Bruno
October 3, 2013, 00:06 |
Frank Yu
Rep Power: 15 |
Thanks Bruno. Problem solved.
I copied an example from an older version where 'type' becomes 'typemodel', that's why the error message comes up. |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Problems with unsteady transonic solver | Frank | Main CFD Forum | 0 | July 24, 2006 14:48 |
Solver Software (?) problems | JvK | CFX | 5 | August 9, 2002 14:33 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
Solving 2-d problems by 3-d solver | eddy | Main CFD Forum | 3 | September 7, 2000 07:15 |
