September 20, 2013, 10:55 |
#21 |
Gerhard Holzinger
Rep Power: 28 |
That way just a thought to demonstrate where the error messages from checkMesh come from. So thats not essential to run the case.
Moving the node is also not applicable to real-world cases, because it would be first of all a horror and secondly a vast un-expiring source of error. However, if you think about how OpenFOAM does local mesh refining, then you also introduce hanging nodes into your mesh. o------o-----o |xxxx |xxxx| o--o--o--o--o |x |x | x |x | o--o--o--o--o If you want to learn more about OpenFOAM, play around with it and study the sources. You have to do this on your own. Others can teach you, but you have to learn. |
November 8, 2018, 10:22 |
CheckMesh interpretation
#22 |
Clément Gouriou
Rep Power: 13 |
Hello openFoamers,
I just have tried to use the extrudeMesh utility to extract only one cell in the z-direction of a 3D domain in order to reduce the number of cell. Then I want to check the mesh quality of the new extrusion? Here below: the results of the checkMesh Code:
Checking geometry... Overall domain bounding box (-150 -50 0) (50 50 0.1) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-5.65759e-20 1.68847e-19 -8.78095e-15) OK. Max cell openness = 2.31794e-16 OK. Max aspect ratio = 52.9876 OK. Minimum face area = 8.35319e-06. Maximum face area = 0.260762. Face area magnitudes OK. Min volume = 8.35319e-07. Max volume = 0.0260762. Total volume = 1998.9. Cell volumes OK. Mesh non-orthogonality Max: 64.9 average: 3.05361 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.39075 OK. Coupled point location match (average 1.42672e-14) OK. Face tets OK. Min/max edge length = 0.00295946 0.521806 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 1 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 0 average: 6.80634e-38 ***Cells with small determinant (< 0.001) found, number of cells: 240189 <<Writing 240189 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 1814 <<Writing 1814 concave cells to set concaveCells Face interpolation weight : minimum: 0.16318 average: 0.488491 Face interpolation weight check OK. Face volume ratio : minimum: 0.147726 average: 0.956426 Face volume ratio check OK. Failed 2 mesh checks. 1st question: I wonder if the "Failed 2 mesh checks" are a real problem for the running of a komegaSST solver or another solver? I enclose a screenshot of the extruded mesh of my airfoil to help to picture the situation of the Mesh. 2d question: I wonder to which extend the "aspect ratio" influence the convergence (duration and success) of a calculation and sometimes makes the solver crash. Before the extrusion I had a "Max aspect ratio" equal to 5.8 but after the extrusion I get a "Max aspect ratio" of 53 (in red above)! What do you think about this topic? Thank you for your answer. Clément |
[Other] How to delete cells in OF based on CheckMesh? | AndTen | OpenFOAM Meshing & Mesh Conversion | 15 | July 27, 2018 07:13 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 06:16 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 22:39 |
Checkmesh shows fault in snappyhexmeshed pipe | senol | OpenFOAM | 2 | July 13, 2012 15:12 |
[Other] CheckMesh for mesh quality | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 2 | October 18, 2007 01:11 |
