spray droplet distortion parameter
Old   September 13, 2013, 13:58
Default spray droplet distortion parameter
dkxls's Avatar
Armin
dkxls will become famous soon enough
Can somebody explain me why the droplet distortion parameter 'y' is limited to positive values in the TAB oscillation equation?
This is done in the lagrangianSpray (2.2.x) [1] and dieselSpray (2.0.x) [2] library.
To my understanding y=0 corresponds to spherical droplet, a positive deformation flattens the droplet perpendicular to the flight directions (y>0) and a negative deformation elongates the droplet (y<0) in flight direction.
I do understand the implications concerning the distorted sphere model due to Liu (1993), i.e. 0<y<1, but this doesn't explain why the distortion parameters y and yDot are set to 0.0 as soon as y is negative.
I would be happy about any comment/explanation on this issue.
-Armin
Here the links to the source code
[1] https://github.com/OpenFOAM/OpenFOAM...yParcel.C#L419
[2] https://github.com/OpenFOAM/OpenFOAM...upModel.C#L121
References:
Liu, A.B.; Mather, D.; Reitz, R.D., "Effects of Drop Drag and Breakup on Fuel Sprays," SAE Paper 930072, SAE Transactions, Vol. 102, Section 3, Journal of Engines, pp. 63-95, 1993
dkxls is offline   Reply With Quote
Old   September 17, 2013, 13:48
dkxls's Avatar
Armin
I reported a bug on this issue:
http://www.openfoam.org/mantisbt/view.php?id=1018
If somebody would still have a comment/explanation, please also write it to the bug tracker.
dieselspray, distortion, lagrangianspray, spray
[General] Glyph filter for spray droplet visualization athlonshi ParaView 1 November 1, 2012 20:51
Spray total droplet momentum calculation help tarnsharma AVL FIRE 0 July 19, 2012 09:17
Parameter Spray Injection sheintz STAR-CD 0 April 1, 2010 08:30
spray & droplet manoj ugale FLUENT 1 March 10, 2006 05:02
Droplet distortion in UDF? HS FLUENT 0 February 20, 2006 09:09
