setfields for alpha
Old   September 13, 2013, 10:14
Default setfields for alpha
belkadi
belkadi is on a distinguished road
Dear Foamers,
I've created a geometry to simulate air injection into a tank filled with water as shown in the attached file.
I've also used the setFields to define the alpha in the system.
alpha =1 for the water inside the tank.
alpha =0 for the air in the injector (by suing the celltobox).
I have some problems with this. I could not define these alpha in my mesh. I think that I've missed something, after processing all the geometry is with alpha = 1 although using the celltobox with alpha = 0 !
Please could anyone help me ?
Thanks in advance !
Kind regards
// blockMesh : Block mesh description file
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
//5 mm column diameter
//10 cm length
//Width of middle square section
//how many cells in the square section
//how many cells from square section to perimeter
// how many cells from top to bottom
vertices
// partie cylindre sup
( 1.25 0.0 1.25) // Vertex fiveoclocksqb = 0
(-1.25 0.0 1.25) // Vertex sevenoclocksqb = 1
(-1.25 0.0 -1.25) // Vertex elevenoclocksqb = 2
( 1.25 0.0 -1.25) // Vertex oneoclocksqb = 3
( 1.76776695455285 0.0 1.76776695137989) // Vertex fiveoclockcb = 4
(-1.76776695455285 0.0 1.76776695137989) // Vertex sevenoclockcb = 5
(-1.76776695455285 0.0 -1.76776695137989) // Vertex elevenoclockcb = 6
( 1.76776695455285 0.0 -1.76776695137989) // Vertex oneoclockcb = 7
( 1.25 4 1.25) // Vertex fiveoclocksqt = 8
(-1.25 4 1.25) // Vertex sevenoclocksqt = 9
(-1.25 4 -1.25) // Vertex elevenoclocksqt = 10
( 1.25 4 -1.25) // Vertex oneoclocksqt = 11
( 1.76776695455285 4 1.76776695137989) // Vertex fiveoclockct = 12
(-1.76776695455285 4 1.76776695137989) // Vertex sevenoclockct = 13
(-1.76776695455285 4 -1.76776695137989) // Vertex elevenoclockct = 14
( 1.76776695455285 4 -1.76776695137989) // Vertex oneoclockct = 15
// partie injecteur
(-1.25 -2 0.11) // Vertex sevenoclockct = 16
(-1.75 -2 0.11) // Vertex elevenoclockct = 17
(-1.75 -2 -0.11) // Vertex sevenoclockct = 18
(-1.25 -2 -0.11) // Vertex elevenoclockct = 19
(-1.25 -2.22 0.11) // Vertex sevenoclockct = 20
(-1.75 -2.22 0.11) // Vertex elevenoclockct = 21
(-1.75 -2.22 -0.11) // Vertex sevenoclockct = 22
(-1.25 -2.22 -0.11) // Vertex elevenoclockct = 23
// partie cone
( 0.625 -2 0.625) // Vertex fiveoclocksqb = 24
(-0.625 -2 0.625) // Vertex sevenoclocksqb = 25
(-0.625 -2 -0.625) // Vertex elevenoclocksqb = 26
( 0.625 -2 -0.625) // Vertex oneoclocksqb = 27
( 0.88 -2 0.88) // Vertex fiveoclockcb = 28
(-0.88 -2 0.88) // Vertex sevenoclockcb = 29
(-0.88 -2 -0.88) // Vertex elevenoclockcb = 30
( 0.88 -2 -0.88) // Vertex oneoclockcb = 31
// partie cone bas (après injecteur) 1
( 0.625 -2.4 0.625) // Vertex fiveoclocksqb = 32
(-0.625 -2.4 0.625) // Vertex sevenoclocksqb = 33
(-0.625 -2.4 -0.625) // Vertex elevenoclocksqb = 34
( 0.625 -2.4 -0.625) // Vertex oneoclocksqb = 35
( 0.88 -2.4 0.88) // Vertex fiveoclockcb = 36
(-0.88 -2.4 0.88) // Vertex sevenoclockcb = 37
(-0.88 -2.4 -0.88) // Vertex elevenoclockcb = 38
( 0.88 -2.4 -0.88) // Vertex oneoclockcb = 39
// partie cone bas (après injecteur) 2
( 0.625 -2.22 0.625) // Vertex fiveoclocksqb = 40
(-0.625 -2.22 0.625) // Vertex sevenoclocksqb = 41
(-0.625 -2.22 -0.625) // Vertex elevenoclocksqb = 42
( 0.625 -2.22 -0.625) // Vertex oneoclocksqb = 43
( 0.88 -2.22 0.88) // Vertex fiveoclockcb = 44
(-0.88 -2.22 0.88) // Vertex sevenoclockcb = 45
(-0.88 -2.22 -0.88) // Vertex elevenoclockcb = 46
( 0.88 -2.22 -0.88) // Vertex oneoclockcb = 47
blocks
//square block
hex (
1 0 3 2
9 8 11 10
(10 10 5)
simpleGrading (1 1 1)
//slice1
hex (
5 4 0 1
13 12 8 9
(10 10 5)
//slice2
hex (
1 2 6 5
9 10 14 13
(10 10 5)
//slice3
hex (
2 3 7 6
10 11 15 14
(10 10 5)
//slice4
hex (
3 0 4 7
11 8 12 15
(10 10 5)
// cone
//square block
hex (
25 24 27 26
1 0 3 2
(10 10 5)
//slice1 bis
hex (
29 28 24 25
5 4 0 1
(10 10 5)
//slice2 bis
hex (
25 26 30 29
1 2 6 5
(10 10 5)
//slice3bis
hex (
26 27 31 30
2 3 7 6
(10 10 5)
//slice4bis
hex (
27 24 28 31
3 0 4 7
(10 10 5)
// cone bas (après injecteur)
//square block
hex (
33 32 35 34
41 40 43 42
(10 10 5)
//slice1
hex (
37 36 32 33
45 44 40 41
(10 10 5)
//slice2
hex (
33 34 38 37
41 42 46 45
(10 10 5)
//slice3
hex (
34 35 39 38
42 43 47 46
(10 10 5)
//slice4
hex (
35 32 36 39
43 40 44 47
(10 10 5)
// cone bas 2 (après injecteur)
//square block
hex (
41 40 43 42
25 24 27 26
(10 10 5)
//slice1
hex (
45 44 40 41
29 28 24 25
(10 10 5)
//slice2
hex (
41 42 46 45
25 26 30 29
(10 10 5)
//slice3
hex (
42 43 47 46
26 27 31 30
(10 10 5)
//slice4
hex (
43 40 44 47
27 24 28 31
(10 10 5)
//injecteur
hex (
21 20 16 17
22 23 19 18
(10 10 10)
//create the quarter circles
edges
// pour cylindre
arc 4 5 (0.0 0.0 2.5)
arc 5 6 (-2.5 0.0 0.0)
arc 6 7 (0.0 0.0 -2.5)
arc 7 4 (2.5 0.0 0.0)
arc 12 13 (0.0 4 2.5)
arc 13 14 (-2.5 4 0.0)
arc 14 15 (0.0 4 -2.5)
arc 15 12 (2.5 4 0.0)
// pour cone
arc 28 29 (0 -2 1.25)
arc 29 30 (-1.25 -2 0)
arc 30 31 (0 -2 -1.25)
arc 31 28 (1.25 -2 0)
// pour cone bas 1 après injecteur
arc 36 37 (0 -2.4 1.25)
arc 37 38 (-1.25 -2.4 0)
arc 38 39 (0 -2.4 -1.25)
arc 39 36 (1.25 -2.4 0)
// pour cone bas 2 après injecteur
arc 44 45 (0 -2.22 1.25)
arc 45 46 (-1.25 -2.22 0)
arc 46 47 (0 -2.22 -1.25)
arc 47 44 (1.25 -2.22 0)
// pour injecteur
arc 16 19 (-2.5 0.40 0)
arc 16 20 (-2.5 0.56 0.16)
arc 20 23 (-2.5 0.72 0)
arc 23 19 (-2.5 0.56 -0.16)
arc 17 18 (-3 0.40 0)
arc 17 21 (-3 0.56 0.16)
arc 21 22 (-3 0.72 0)
arc 22 18 (-3 0.56 -0.16) */
boundary
inlet
type wall;
faces
(21 17 18 22)
leftWall
type wall;
faces
(37 45 46 38)
(45 29 30 46)
(5 13 14 6 )
rightWall
type wall;
faces
(36 28 31 39)
(28 4 7 31)
(4 12 15 7)
upperWall
type wall;
faces
(13 14 15 12)
lowerWall
type wall;
faces
(37 38 39 36)
frontAndBack
type empty;
faces
(17 21 20 16)
(18 22 23 19)
(37 45 44 36)
(38 46 47 39)
(45 29 28 44)
(46 30 31 47)
(29 5 4 28)
(30 6 7 31)
(5 13 12 4)
(6 14 15 7)
patches
for the setFields file :
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue alpha1 1
//volScalarFieldValue U (0 0 0)
regions
boxToCell
box (-1.75 -2.22 0.11) (-1.25 -2 -0.11);
fieldValues
volScalarFieldValue alpha1 0
Thanks !
Krimo
belkadi is offline   Reply With Quote
Old   September 13, 2013, 10:27
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you attach archive of you case it'll be easier to figure out what is wrong. Also if you'd like to insert blockMeshDict and setFieldsDict in the post, please, use [CODE] tags.
alexeym is offline   Reply With Quote
Old   September 13, 2013, 10:56
Bernhard
Bernhard is on a distinguished road
You set the default value to 1 and, after that, alpha to 0 inside the box in setFieldsDict. If you want to invert it, invert these values in the dictionary.
Bernhard is offline   Reply With Quote
Old   September 16, 2013, 06:39
belkadi
Thanks for your reply Bernhardt, I tried your solutuion but it doesn't work.
In attached file the code source. Please if you have time you can check this problem.
Thanks in advance !
Kind regards
Krimo
Old   September 16, 2013, 06:47
Alexey Matveichev
In setFieldsDict you need to change this
to this
box  (-1.75   -2.22   -0.11) (-1.25 -2  0.11);
I think setFields doesn't like that Z of the first box point is higher than of the second.
Old   September 16, 2013, 06:58
belkadi
DearAlexeym,
Excellent, now it works !
it's magic
Thank you very much for your help. I spent 3hours looking for this problem !
Again thank you very much
Kind regards
Krimo
Old   September 22, 2013, 21:59
Dongyue Li
sharonyue is on a distinguished road
May I know why dont you use ICEM or the others but blockMesh? blockMesh is not convenient dealing with this.
sharonyue is offline   Reply With Quote
Old   November 25, 2014, 12:53
Default setFields
minoominaii
bgane67 is on a distinguished road
i want to design a nuzzle with cylinder ,what should i replace in setfieldsDict
(region)?sphereToCell or boxToCell?
bgane67 is offline   Reply With Quote
how to use setFields in multiregionsolver lg88 OpenFOAM 18 June 12, 2022 19:57
InterFoam - setFields for a non-rectangular 3D domain Ak_cfd OpenFOAM Running, Solving & CFD 24 July 25, 2020 22:16
setFields not working dsanza OpenFOAM 4 October 18, 2018 10:43
Problems with the execution of the setFields utility. foamer OpenFOAM Pre-Processing 5 June 3, 2013 13:24
setFields tool does not assign water volume for given mesh. paka OpenFOAM 2 June 7, 2012 10:17
