discretizing void fraction transport equation |
September 9, 2013, 12:40 |
Rep Power: 16 |
Hi everybody,
I am having a really hard time for discretizing the transport equation for void fraction in OpenFOAM. The equation is as following: d(alpha)/dt+U.Δ(alpha)=Δ.J and J is a function of alpha. I appreciate it if you help me to write it in OpenFOAM format. Thanks. |
September 10, 2013, 03:23 |
Bernhard
Rep Power: 22 |
What did you try up until now? Where are you stuck exactly? Have a look at $FOAM_SOLVERS/basic/scalarTransportFoam
September 10, 2013, 14:25 |
Rep Power: 16 |
Thanks for your response. I describe for you the whole story. The equation that I have put in my first post d(alpha)/dt+U.Δ(alpha)=Δ.J is the governing equation for the transport of particles in a suspension due to normal stresses (Δ is the divergence operator here). The normal stress is the J term in the right hand side.
The process that I have done to reach the J equation is: SP=-etha0*gamma*ethaN*Q Here, etha0 and ethaN are viscosity, gamma is the magnitude of the strain rate and Q is a tensor. In OpenFOAM format it is : volTensorField SP = -1.0*etha0*sqrt(magSqr(symm(fvc::grad(U))))*ethan*Q To find J, i have done: volVectorField divSP = fvc::div(SP); volVectorField J= (-2.0*aa*aa/9.0/etha0)*fphi*divSP; As you see J is a vector which is calculated based on a divergence process on a tensor field. I do not know if the divergence calculation is correct or not. Having the J vector field, I have written the transport equation of void fraction: fvScalarMatrix alphaEqn ( fvm::ddt(alpha) + fvm::div(phic, alpha, scheme) - fvc::div(J) ); As you see another divergence is applied to J. So now I do not know first: if the two divergence process that I have done are written correctly in OpenFOAM format or not, second: is my transport equation which is the discretized form of the equation presented in my first post correct or not? I appreciate if any body can help me. |
September 11, 2013, 09:27 |
Rep Power: 16 |
any answer?!
Transport equation in CFX | D.ko | CFX | 0 | August 9, 2013 08:57 |
Sub-iterations for transport equation in drift-flux | Siemen | OpenFOAM Programming & Development | 2 | July 5, 2013 07:06 |
how to make a scalar transport equation to be conserved? | immortality | OpenFOAM Programming & Development | 3 | May 5, 2013 09:11 |
Implement species transport equation | Tobi | OpenFOAM Programming & Development | 0 | June 2, 2012 14:26 |
Source Term on Scalar Transport Equation - crashing simulation | alessio.nz | OpenFOAM | 19 | February 8, 2011 08:38 |
