Overwriting output time
Old   August 27, 2013, 10:44
Default Overwriting output time
Tony Ladd
tladd is on a distinguished road
I am new to OpenFoam and am using SIMPLE to solve the Stokes equations - grad p = nu grad^2 U. Since they are a time independent component of a multistage solver I want to prevent the time value from incrementing during the SIMPLE iteration (simple.loop). Any suggestions? I looked at SimpleControl.C but I could not figure out where the runtime.timeName() is being incremented. This program is very useful but its way too clever for me.
Thanks
Tony
tladd is offline   Reply With Quote
Old   September 1, 2013, 09:00
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Tony,
If I understand you correctly, then you are developing something with this type of structure:
while OuterTimeLoop
O1. Some operations
while InnerTimeLoop
I1. Produce steady state solution
end
O2. Some more operations based on steady state solution.
end
From the top of my head, I would probably try to work with two Time objects (e.g. runTime and runTimeInner). one, which is constructed before the OuterTimeLoop and then one, which you construct each and every time before the InnerTimeLoop. In this way, you will have a time increment for the outer (transient?) time loop, which is independent of the steady state solution, which might even work with a different time stepping, Courant criterion, etc. This can then be control by given the InnerTimeLoop a second controlDict, say controlDictInner.
The only thing you will need to be aware of, is that there might be the need of a duplicate of variables and some corresponding mapper, such that they carry the correct time information depending on the use of the variables, but I do not have an answer for that.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Rapidly decreasing deltaT for interDyMFoam chrisb2244 OpenFOAM Running, Solving & CFD 3 July 1, 2014 17:40
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 08:11
