July 16, 2013, 05:18 |
interFoam solver for air injection
belkadi
Rep Power: 13 |
Dear Foamers,
I would like to use the interFOAM solver for my personal test case. Starting from the : FOAM_TUTORIALS/multiphase/interFoam/laminar/damBreak The example shows the ascent of a bubble of air through the column. I would like to add an injection of a continuous air flow rate from the bottom. How could I add the air flow rate ? Should I add it in the setFields ? I looked for many examples in the tuto and I did not found examples to show the flow rate design. May be I missed something. Any suggestions are welcome. Thanks for advance ! Kind regards krimo |
July 16, 2013, 06:10 |
Wouter van der Meer
Rep Power: 18 |
If you look in the tutorials there are several bubble colums. Have a look at those Good luck and happy foaming wouter |
July 25, 2013, 04:58 |
belkadi
Rep Power: 13 |
Hi Wouter !
Thanks for the answer, Yes I found many interesting examples. I'm running some of them to get hand with OpenFoam. Do you know if I can find example which use for example gas or steam injection through a nozzle into a column or a tank ? Again many thanks ! Kind regards Krimo |
August 2, 2013, 03:13 |
Hi Belkadi,
I am trying to simulate a oil tank with an air injection. Did you manage to solve your task? Can you explain to me how did you manage to have the air flow rate? Thanks Regards Marco |
Problem of InterFoam with LES SpalartAllmarasIDDES | keepfit | OpenFOAM | 3 | August 29, 2013 12:21 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 19:06 |
atmosphere bc in dam brake case (interFoam solver) | Mike H. | OpenFOAM Running, Solving & CFD | 0 | July 30, 2009 07:35 |
interface tension question with interFoam solver | openTom | OpenFOAM Running, Solving & CFD | 4 | May 29, 2009 14:18 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
