Alternative formulation of momentum equation
Old   June 30, 2013, 14:05
Default Alternative formulation of momentum equation
Thomas K.
TomKopp is on a distinguished road
Is it possible to use
fvm::div(phi, U)
- fvc::div(tau)
instead of
fvm::div(phi, U)
- fvm::laplacian(fluid.nu(), U)
- (fvc::grad(U) & fvc::grad(fluid.nu()))
which is the standard formulation in non-Newtonian, steady-state solvers?
I would like to modify the stress tensor before the momentum equation is solved (i.e. include the elongational viscosity in normal direction).
For the energy equation this is already working:
// calculate stress tensor
volTensorField gradU = fvc::grad(U);
volTensorField tau = fluid.nu() * (gradU + gradU.T());
tau.component(tensor::XX) = tau.component(tensor::XX) / max(dimensionedScalar ("VSMALL", dimensionSet(0,2,-1,0,0,0,0), VSMALL), fluid.nu()) * elongFluid.nuElong();
tau.component(tensor::YY) = tau.component(tensor::YY) / max(dimensionedScalar ("VSMALL", dimensionSet(0,2,-1,0,0,0,0), VSMALL), fluid.nu()) * elongFluid.nuElong();
tau.component(tensor::ZZ) = tau.component(tensor::ZZ) / max(dimensionedScalar ("VSMALL", dimensionSet(0,2,-1,0,0,0,0), VSMALL), fluid.nu()) * elongFluid.nuElong();
// energy equation
tmp<fvScalarMatrix> TEqn
    fvm::div(phi, T)
  - fvm::laplacian(alpha, T)
  - 1.0/Cp * (tau && gradU)
TEqn().relax();
solve(TEqn());
However, when I use Gauss linear scheme for div((nu*(grad(U)+grad(U).T()))) the time step continuity error gets very high after only one step.
Does anyone have an idea how to solve the problem? Thank you in advance!
TomKopp is offline   Reply With Quote
Old   July 1, 2013, 13:07
Default Stress tensor
Thomas K.
Even if I use
without the elongational viscosity and then for the momentum equation
fvm::div(phi, U)
- fvc::div(tau)
it is not working (time step continuity error very high).
How can I tell OpenFOAM to solve
fvc::div(tau)
correctly?
Old   July 1, 2013, 14:04
Default Explicit (fvc) and implicit derivative (fvm)
Thomas K.
Can it be due to the use of an explicit (fvc) instead of an implicit derivative (fvm)? Do I have to use an transient solver or should it also work for a steady-state solver like simpleFoam?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Question on the discretization of momentum equation in icoFoam MPJ OpenFOAM 3 October 4, 2011 10:44
Discretization of momentum equation query siw CFX 0 June 20, 2011 09:38
Question on momentum equation in VOF or Level Set Kai Yan Main CFD Forum 0 January 11, 2008 09:47
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 17:51
