Troubles when create a new volScalarField in my own library |
X Meng
Rep Power: 14 ![]() |
Dear all,
I'm struggling to create a new volScalarField variable in my own function before compiling my own source code, the exactly same thing like pressure, density, viscosity, etc. But failed again and again, any suggestion please? ![]() |
Nima Samkhaniani
Rep Power: 24 ![]() |
fail? your question is too vague, atleast post your error line
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
X Meng
error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField()’
Nima Samkhaniani
would you mind!, add your pieces of code here too
Bernhard
Rep Power: 21 ![]() |
X Meng
A very simple test, the header file (XXX.H) is:
#include "fvCFD.H" #include "IOstream.H" #include "messageStream.H" namespace Foam { namespace Test { class Try { public: volScalarField value1,value2; static volScalarField newField( ); }; } } The implement file (XXX.C) is: #include "XXX.H" namespace Foam { namespace Test { volScalarField value1; volScalarField Try::newField( ); volScalarField value2; value2=value1; return (value2); } } To generate a new library, I have tried with some 'int' type functions and variables in this way, they can be compiled and work well to be called in a main program. But when the variable type is 'volScalarField', did I miss something? Like other header files to include? |
Bernhard
As far as I can see, you are trying to call a volScalarField constructor without any arguments. There is no such constructor, see: http://foam.sourceforge.net/docs/cpp/a00776.html , to construct a volScalarField, you need at least a mesh somewhere.
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 09:55 |
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? | lzgwhy | ANSYS Meshing & Geometry | 5 | May 18, 2017 17:10 |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
