Overwriting Temperature in OpenFoam
Old   June 7, 2013, 10:20
Default Overwriting Temperature in OpenFoam
Ivana
IvanaS is on a distinguished road
I coupled reactingFoam with the combustion in-house code that provides me density and temperature. I send temperature and density to OpenFoam in order to update flow field. OpenFoam uses density from combustion code properly but I have problems with temperature. OpenFoam doesn't use the temperature from the separate combustion code but one from basicThermo.
Does someone has any suggestion how to overwrite temperature in OpenFoam and make OpenFoam to use temperature calculated in the other code?
Is there a way to do it without modifying basicThermo files?
Thank you very much.
Regards,
Ivana
IvanaS is offline   Reply With Quote
Old   June 8, 2013, 07:18
HECKMANN Frédéric
fredo490 is on a distinguished road
I made somthing similar few weeks ago, here is the solution:
http://www.cfd-online.com/Forums/ope...implefoam.html
fredo490 is offline   Reply With Quote
Old   June 10, 2013, 09:17
Ivana
Thank you for your reply.
But would it be possible that I copy basicThermo to my own implementation of reactingFoam and modify it and use it from there? I am not sure how to do that? Would I also need to have "turbulenceModels/compressible/turbulenceModel" in the same directory?
I am asking this because if I change basicThermo in the top-level solver that might also influence other users of OpenFoam...
Thank you!
Regards,
Ivana
Old   June 10, 2013, 11:57
HECKMANN Frédéric
If you do the modification I made in the other topic (add a member to get a variable T and not a constant T), there is no problem with the other solvers. I currently use it on my OpenFoam and everything runs fine. It simply "add" an extra function/possibility, it doesn't change anything.
But you can make it local if you want. I had this topic few weeks ago: http://www.cfd-online.com/Forums/ope...ion-2-2-a.html
I haven't got time to write a "tutorial" yet.
Old   June 25, 2013, 06:17
Ivana
It is working! Thank you!
Regards,
Ivana
Old   June 25, 2013, 08:32
HECKMANN Frédéric
You are welcome. It seems that the last update from OF 2.2 includes a code similar to the one I've showed you. So, if you don't want to change everything next time, just update OF.
Old   June 25, 2013, 08:34
Ivana
That's good to know. Thanks once more!
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
coldEngineFoam (OpenFoam 2.1.x), constant Temperature during adiabatic compression novakm OpenFOAM Verification & Validation 1 February 25, 2013 13:25
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
