Need help with modifying setPressure.H
Old   June 5, 2013, 02:28
Default Need help with modifying setPressure.H
haze_1986 is on a distinguished road
Hi all, I am currently trying to develop a coupled solver. I am currently at the stage of coding the transfer of information between the 2 solvers. I am following the template setPressure.H due to the similarities.
    Info << "Setting " << endl;
    // interpolates the pressure from the fluid field to the
    // solid patches at the fluid-solid boundary
    scalarField solidPatchPressure =
        interpolatorFluidSolid.faceInterpolate
            p.boundaryField()[fluidPatchID]
    solidPatchPressure *= rhoFluid.value();
    // tforce is Reference for traction displacement BC
    tForce.pressure() = solidPatchPressure;
    // calculates total force from pressure
    vector totalPressureForce =
        sum
            p.boundaryField()[fluidPatchID]*
            mesh.Sf().boundaryField()[fluidPatchID]
    Info << "Total pressure force = " << totalPressureForce << endl;
Can anyone guide me on what has to be changed if I were to require the depth and velocity of shallowWaterFoam to be patched onto z(level) and velocity of interFoam?
haze_1986 is offline   Reply With Quote
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 04:56
modifying radial distribution function ravindra FLUENT 2 September 2, 2014 14:03
Modifying FLUENT plots siw FLUENT 2 April 4, 2013 10:53
Modifying density update in fireFoam anfho OpenFOAM Programming & Development 3 March 22, 2011 03:02
Modifying Gambit DBS file Created from MixSim 2 gkennedy3 ANSYS Meshing & Geometry 0 August 7, 2009 09:32
