May 28, 2013, 11:39 |
Problem with setting initial field
LI Bo
Rep Power: 13 |
I want to set the initial field (for example, scalar field s) in a centrosymmetric computational domain (for example, a cube [-1,1]*[-1,1]*[-1,1]) with: (1) for the region z>=0, the field is a random field. (2) for the region z<0, s(x,y,z)=-s(-x,-y,-z). Anyone can teach me how to realize this initialization? I am new to OpenFOAM. Thanks. |
May 30, 2013, 19:12 |
Thomas Boucheres
Rep Power: 13 |
The quickest/simplest way is to write "hard coded" functionality directly in the code source of the solver you want to use. But dirty job!
The cleaner/right way is to use a codedFunctionObject and writing your initialisation in the read section for example. Here is an example of possible implementation: //////////////////////////////////////////////////////////////////////////// codedInitFields { // Load the library containing the 'coded' functionObject functionObjectLibs ("libutilityFunctionObjects.so"); type coded; // Name of on-the-fly generated functionObject redirectType codedInit; // Compilation rules codeOptions #{ -I$(LIB_SRC)/OpenFOAM/lnInclude #}; codeLibs #{ -lOpenFOAM #}; codeInclude #{ #include "volFields.H" #include "surfaceFields.H" #include "pointFields.H" #}; codeData #{ // Do nothing #}; codeRead #{ // Name of the field to initialise word fieldName_ = "XXXXX"; //Search the field you want to initialise in the db Info<< "coded : Looking up field " << fieldName_ << endl; //I suppose your field is a vectorField. Adapt it. if (mesh().foundObject<volVectorField>(fieldName_)) { const volVectorField& field = mesh().lookupObject<volVectorField>(fieldName_); forAll (field,cellI) { const point& p = mesh().cellCentres()[cellI]; if (p.z()>=-VSMALL) { //do your job field[cellI].x() = p.x(); field[cellI].y() = 2*p.y(); field[cellI].z() = 3*p.z(); } else { //assume GREAT is not used in z>0 part! field[cellI] = 2*GREAT; } } // Costly procedure... If your mesh is cartesian, uses // associated indexation to avoid findCell. forAll (field,cellI) { const point& p = mesh().cellCentres()[cellI]; if (p.z()<=VSMALL && field[cellI]>GREAT) { point pSym(-p); label cellSymI = mesh().findCell(pSym); field[cellI] = field[cellSymI]; } } } #}; codeExecute #{ // Do nothing #}; codeEnd #{ // Do nothing #}; code #{ // Do nothing #}; } /////////////////////////////////////////////////////////////////////// Don't forget to activate the allowSystemOperations flag in the etc/controlDict file (set "allowSystemOperations 1"); |
June 8, 2018, 01:03 |
#3 | |
Ben 017
Rep Power: 9 |
Hello, Me I want to map a cylinder on a Cartesian grid, the cartesian grid is already made and has the center(0,0,0). May you help to know hoe it is done? I would appreciate! |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 14:52 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 08:11 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
