Locate a cell with a specific wall Distance value
Old   May 28, 2013, 10:26
Post Locate a cell with a specific field value
M. Montero
be_inspired is on a distinguished road
Hi all,
My intention is know where is the cell with the lowest distance to the wall without using paraFoam. It would give me an indication about where is the problem in the mesh and where I have to change the mesh.
           Info<< "Calculating wall distance using wallDist function\n" << endl;
           wallDist y(mesh, true);
           Info<< "Writing wall distance to field zDistance" << endl;
           zDistance.internalField()= y;
           Info << " Minimum z Distance"<< min(zDistance) << endl;
           zDistance.write();
	   Info << "location"<< mesh.findCell(zDistance=??)<< endl;
I have looked for it around the forum but I do not know how to extract the cellID of that specific cell and so, to use the mesh.C() option.
Please, could someone help me.
Thanks.
be_inspired is offline   Reply With Quote
Old   May 28, 2013, 14:57
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Marcelino,
As far as I know, you have to do a search for the cell in question. The brute-force solution is simply to do the following (note, just written out, it might be adjusted for compilation):
label cellIndex = 0;
forAll( mesh.C(), celli )
    if ( y[celli] < y[cellIndex] )
        cellIndex = celli;
Info << "The cell index with smallest distance:" << tab << cellIndex << endl;
This will be a bit slow, so I would suggest simply to search all of the cells along the boundaries. You could e.g. do something like the following:
forAll( y.boundaryField(), patchi )
    const labelList & faceCells = mesh.boundaryMesh()[patchi].patch().faceCells(); // Something like this, but might not compile.
    forAll( faceCells, celli )
        if ( y[faceCells[celli]] < y[cellIndex] )
             cellIndex = faceCells[celli];
Kind regards
Niels
ngj is offline   Reply With Quote
Old   May 29, 2013, 06:43
M. Montero
Hi Niels,
Thank you very much.I have chosen the second option and works great in a mesh of 20 millions of elements. The only point is that, al least for OF2.1.1, I had to delete a patch() word in one of your code lines.
I post the last version here if someone needs the tool or has to modify it for other purposes.
Thanks a lot
Marcelino
int main( int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
           y.write();
           Info<< "Analyzing minimum cell Distance" << endl;
	   label cellIndex=0;
	   forAll ( y.boundaryField(),patchi)
		const labelList & faceCells = mesh.boundaryMesh()[patchi].faceCells();
		forAll (faceCells, celli)
	    Info << "Minimum wall distance" << tab << y[cellIndex] << endl;
	    Info << "Location of the cell with minimum wall distance (X Y Z)" << mesh.C()[cellIndex] << endl;
    return 0;
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 15:41
wall layer distance in ICEM HEXA F.K. CFX 0 November 3, 2004 04:48
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
distance from the wall to the first grid point Wenqing Zhang CFX 0 August 9, 2004 11:08
