Is there a template for this problem (convection)?
Old   May 24, 2013, 12:29
Default Is there a template for this problem (convection)?
Andrew Somorjai
massive_turbulence is on a distinguished road
Hello All,
I wondered if the OpenFoam template library had a setup for a problem where I have a container filled with a gas (lets say air) and I used convection to heat up the gas.
Description of problem:
The container is 2d or 3d which can be either square or cubic and the boundaries can also be arbitrary but the point of the problem is to illustrate convection.
For the 2d problem; the square is made of 4 walls, 3 of which are perfect insulators and one is a perfect conductor (or made of tungsten) and a flame is adiabatically heating the tungsten side of the square container (this is the 2d version of the problem).
The air inside the container has initial conditions of being isotropic and at room temp and as the conductive part of the square heats up, the pressure on the walls becomes evenly spread out but the distribution of heat inside the container is not evenly spread out due to convection.
Is there some easy way to solve this with OpenFoam?
massive_turbulence is offline   Reply With Quote
Old   May 25, 2013, 04:55
Nima Samkhaniani
nimasam is on a distinguished road
look at OpenFOAM tutorials in heat transfer section for example following solvers test cases:
bouyantSimpleFoam or bouyantBoussinqSimpleFoam
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
adiabatic, convection, heat flux
Natural Convection heat transfer problem srinivasa FLUENT 21 November 11, 2016 07:08
problem with convection swe704 FLUENT 0 August 10, 2010 11:43
convection diffusion problem ali2108 OpenFOAM 1 May 30, 2009 23:17
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM varghese FLUENT 6 February 6, 2002 06:23
Natural Convection Problem Sridhar FLUENT 2 September 13, 2001 16:16
