#21 |
Hassan
Rep Power: 13 ![]() |
Hello Mr. Bruno
According to the reference that it's address link is below, in page 53; http://www.diva-portal.org/smash/get...T01.pdf I can,t undrestand that what is the placeholder matrix in openFoam? and how get this equations: u(0)=[2,0] u(1)=[3,1] l(0)=[0,2] l(1)=[1,3] UpperAddr=(2,3) LowerAddr=(0,1) If it is possible for you, please explain a little about this concept. Best regards, Hassan |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Hi Hassan,
Sorry, but this is beyond my experience level. My suggestion is that you'll have to search for more information on this topic, possibly among the reference thesis made around OpenFOAM and the OpenFOAM Programmers Guide: http://foam.sourceforge.net/docs/Gui...mmersGuide.pdf Good luck! Best regards, Bruno
#23 |
Hassan
thank you Mr. Bruno
#24 |
Hassan
In the icoFoam solver, where is the top level of Ueqn where Navier-stoke equation carries out? best regards, Hassan |
#25 |
Bruno Santos
Hi Hassan,
The best I can do on this question is to point you to this wiki page: http://openfoamwiki.net/index.php/IcoFoam - it basically explains how the icoFoam solver works. Best regards, Bruno
#26 |
Hassan
Hi friends,
I can't understand the PCG linear solver how work in the icoFoam solver? In other words, which part of the icoFoam.C related to the PCG linear solver and use it? please show me. Regards, Hassan |
#27 |
Bruno Santos
Hi Hassan,
The PCG solver is not available directly to icoFoam. It's used very deep into the solve() methods and equation solving algorithms. Some more reading material:
Bruno
#28 |
Hassan
Thanks.
Regards, Hassan. Last edited by luckycfd; September 20, 2013 at 14:08. |
#29 |
Hassan
Dear Foamers,
How can I extract the linear system (AX=B) from the cavity case in tutorials using OpenFOAM? Regards, Hassan |
#30 |
Hassan
Hi dear Bruno,
Could I use the PCG linear solver for my linear system (Ax=b) separately? In the other words, I want to send two input files A and b, then get the x from this solver? yes or no please? regards, Hassan |
#31 |
Bruno Santos
Hi Hassan,
I'm sorry to say that I don't know the answer. In theory, it should be possible. AFAIK, do keep in mind that PCG will not be able to give you an exact solution. At most, it's able to give you a partial/possible near solution, but not an exact one: http://www.cfd-online.com/Wiki/Conju...adient_methods If I had to start investigating into this, I would have a look into the source code experiments that try to use one or more GPUs to help solve simulations faster, such as:
Best regards, Bruno
#32 | |
Meher
Rep Power: 12 ![]() |
I am also working on the same problem of solving sparse linear matrix (AX=B) using PCG solver. Did you find any solution ? Any useful inputs from your side apart from what is available here? Thanks, Meher. |
#33 |
Hassan
Hi Meher,
thanks for your attention, but no. |
compile, linear solver, openfoam |
Fatal overflow in linear solver (RSM) | Luis | CFX | 12 | October 16, 2019 17:36 |
How to avoid checkerboard? | dohnie | OpenFOAM Programming & Development | 7 | January 26, 2015 03:12 |
ERROR #004100018; Fatal overflow in linear solver | Attila | CFX | 1 | April 13, 2012 22:22 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
free C code for large sparse matrix linear solver | ztdep | Main CFD Forum | 7 | May 24, 2007 14:14 |
