why not reading from script?
Old   May 1, 2013, 15:29
Default why not reading from script?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have put this script (plot)on my desktop as well as some other simple scripts and have given its address to bashrc as below:
PATH=$PATH:/home/ehsan/Desktop/codes
other scripts are working well but plot doesn't by this error:
ehsan@Ehsan-com:~/Desktop/WR_Main_Central$ plot rhoCentralFoam
plot: rhoCentralFoam: No such file or directory
plot: ignoring this file
(for example report file performs fine but plot doesn't)
File Type: gz plot.tar.gz (207 Bytes, 7 views)
File Type: gz report.tar.gz (169 Bytes, 4 views)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 2, 2013, 02:50
haakon will become famous soon enough
Try to use the export command in .bashrc to make the variable global:
export PATH="$PATH:/home/ehsan/Desktop/codes"
haakon is offline   Reply With Quote
Old   May 2, 2013, 05:54
Ehsan
thanks.
but the error is repeated.
Old   May 2, 2013, 06:15
In the top of your plot script, you have the shebang:
#! /bin/sh
try to remove the space, such that it become
#!/bin/sh
Also make sure that you have made the script executable, by calling
chmod +x plot
from the folder with the plot script.
Old   May 2, 2013, 08:31
Ehsan
I removed space.yes its executable.doesn't perform.
Old   May 2, 2013, 08:58
Retired Super Moderator
Bruno Santos
Greetings to all!
@Ehsan: What happens if you run the contents of the script directly on the command line? Namely:
pyFoamPlotRunner.py --hardcopy --with-courant --progress --no-pickled-file rhoCentralFoam
Best regards,
Bruno
Old   May 2, 2013, 09:25
Ehsan
dear Bruno I have been using that untill now and thought it will be better to do that by a short command and script but it doesn't work.
Old   May 2, 2013, 09:32
Bruno Santos
Mmm... strange... OK, then try changing the first line:
#!/bin/sh
To:
#!/bin/bash
If it still doesn't work, try:
#!/bin/bash
which $1
It should tell you where rhoCentralFoam is located, namely it should give the same as running on the command line:
which rhoCentralFoam
Old   May 2, 2013, 10:15
Ehsan
no.which command doesn't work in script but work in terminal:
ehsan@Ehsan-com:~/Desktop/WR_Main_Central$ which rhoCentralFoam
/opt/openfoam220/platforms/linux64GccDPOpt/bin/rhoCentralFoam
Old   May 2, 2013, 10:25
Bruno Santos
I finally understand what's happening... try running:
which plot
#or
type plot
It will probably tell you it's located at "/usr/bin/plot"!
The solution is simple: rename your "plot" script!
Old   May 2, 2013, 11:04
Ehsan
yes that message was shown.then its name is like other script in ubuntu?
but other names don't work:
ehsan@Ehsan-com:~/Desktop/WR_Main_Central$ do rhoCentralFoam
bash: syntax error near unexpected token `do'
ehsan@Ehsan-com:~/Desktop/WR_Main_Central$ runPlot rhoCentralFoam
Old   May 2, 2013, 11:26
Bruno Santos
What does the following command output?
which runPlot
Old   May 2, 2013, 11:37
Ehsan
it knows the path:
ehsan@Ehsan-com:~/Desktop/WR_Main_Central$ which runPlot
/home/ehsan/Desktop/codes/runPlot
but
Old   May 2, 2013, 14:09
Bruno Santos
OK, then confirm the contents of the file... I don't know what it looks like at this point.
If it all makes sense, try changing the first line to this:
#!/bin/bash -x
It should show you what it's doing when the script is executed.
Old   May 2, 2013, 14:25
Ehsan
that says this:
+ solver=rhoCentralFoam
+ pyFoamPlotRunner.py --hardcopy --with-courant --progress --no-pickled-file rhoCentralFoam
Killing PID 14778
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 14778 was already dead
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/14778/status'
Old   May 2, 2013, 14:44
Ehsan
resolved!
sorry,i had changed a postProceesing function meanwhile and didn't test full pyFoam command it terminal after that change.
then it must have been resolved when I had changed its header to
#!/bin/bash
but i learned some more things!
now a simple question how can I set number of processors in line like this:
runPlot 4 rhoCentralFoam
what should i replace for 4 in this code? :
#!/bin/bash
solver=$1
pyFoamPlotRunner.py --hardcopy --with-deltat --with-courant --procnr=4 $solver
Old   May 2, 2013, 15:23
Bruno Santos
#!/bin/bash
solver=$1
I guess you haven't studied properly the other script I made for merging data and the studying references I gave... Anyway, it's very simple:
#!/bin/bash
solver=$2
pyFoamPlotRunner.py --hardcopy --with-deltat --with-courant --procnr=$1 $solver
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
