Promlems with compilation of new solver
Old   April 26, 2013, 03:38
Default Promlems with compilation of new solver
Galchenko Olga
Galchenko is on a distinguished road
Hello!
I installed OpenFoam on my computer and everything worked fine. Now I want to implement new solver and when I try to compile it(I use Allwmake in OpenFoam/application directory) I get such an error:
tesla0@tesla0-desktop:/opt/openfoam210$ sudo ./Allwmake
./Allwmake: 9: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
Though my wmakeCheckPwd file is located in make directory, as it should be, I suppose.
My enviroment variables for OpenFoam are set(including WM_PROJECT_DIR).
if I try to run Allwmake in main OpenFoam installation directory I get the same error.
So I am really puzzled what to do with this.
Do I have to set any extra enviroment variables? Or maybe there is something else?
My version of OpenFoam is 2.1.0, gcc 4.4.3, ubuntu 10.04
Best regards, Olga
Galchenko is offline   Reply With Quote
Old   April 26, 2013, 04:19
akidess's Avatar
Anton Kidess
I'm guessing WM_PROJECT_DIR is set to something in your home folder (check with "echo $WM_PROJECT_DIR"). Instead of compiling using sudo, better just compile as a regular user in WM_PROJECT_DIR.
- Anton
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 26, 2013, 04:44
Lieven
Lieven will become famous soon enough
Hi Galchenko,
You shouldn't have copied the Allwmake file from the main installation dir (based on the error you get, I'm pretty sure this is what you did.
But if it is only one solver you are compiling, there is no need for a Allwmake script. Instead, just make sure you have a Make-folder with the proper 'files' and 'options' in the same directory as the source files of the new solver and simply type
wmake
Cheers,
L
Lieven is offline   Reply With Quote
Old   April 26, 2013, 05:22
Galchenko Olga
Thanks a lot for your quick replies)
Anton, I've checked this and this variable is set as opt/openfoam210, do I understant right that it is not user's directory?
And I have to use sudo, because if not I get an error
mkdir: cannot create folder "linux64GccDPOpt": permission denied
So I have problems with user's rights
L, But I didn't copy allwmake, I tried to run it from main directory..
When I try to run wmake in the directory of the solver I get an error:
sudo: wmake: command not found
Though I have Make-folder with proper files..
Best regards, Olga
Old   April 26, 2013, 08:24
akidess's Avatar
Anton Kidess
Right, that's ok. WM_PROJECT_USER_DIR is where you should put your cases and self-made applications. And if OpenFOAM is properly configured you should just have to type wmake as Lieven mentioned, no need for Allwmake. Did you source etc/bashrc before trying to compile?
Old   April 26, 2013, 09:11
Galchenko Olga
Yes, I did everything about setting variables again as it is mentioned in the instruction: http://www.openfoam.org/download/git.php
I'm not sure my OpenFoam is configured properly. When I run foamInstallationTest, I get
FATAL ERROR: OpenFOAM environment not configured
But I can't catch what I'm missing, as I followed the instructions..
And I checked enviromental variables - all of them were set well.
Should I configure smth else?
Old   April 26, 2013, 09:19
akidess's Avatar
Anton Kidess
Are you aware that you have to source the configurations file every time you want to use OpenFOAM in a new shell? Do this by executing "source /opt/openfoam210/etc/bashrc", and then check if foamInstallationTest still reports an error.
Old   April 26, 2013, 09:22
Lieven
Ok, open a terminal, go to the installation folder and type
pwd && grep foamInstall bashrc
and copy the output here.
Also try
source etc/bashrc
Cheers,
L
Old   April 26, 2013, 09:24
Galchenko Olga
I did as you said, but nothing changed and I got the same error..
Old   April 26, 2013, 09:28
Lieven
Could you first please copy the output from
pwd && grep foamInstall OpenFOAMdir/etc/bashrc
Old   April 26, 2013, 09:32
Galchenko Olga
L, after running this commands I get:
/opt/openfoam210
grep: opt/openfoam210/etc/bashrc: no such file or directory
though this file exists in this directory..
Old   April 26, 2013, 09:42
Lieven
You forgot the first '/':
grep foamInstall /opt/openfoam210/etc/bashrc
Old   April 26, 2013, 09:46
Lieven
Also see what the output is of
echo $FOAM_SRC
If the environment variables are really loaded correctly, this should give
/opt/openfoam210/src
Old   April 26, 2013, 10:36
Galchenko Olga
Really thanks for your recomendations. I'll try them next week and write what I get.
Regards, Olga
Old   April 30, 2013, 03:12
Galchenko Olga
Hello!
echo $FOAM_SRC
I get the right directory here.
And after runnint pwd && grep :
# 'foamInstall' below to where OpenFOAM is installed
foamInstall=/opt
# foamInstall=~$WM_PROJECT
# foamInstall=/opt/$WM_PROJECT
# foamInstall=/usr/local/$WM_PROJECT
: ${FOAM_INST_DIR:=$foamInstall}; export FOAM_INST_DIR
unset cleaned foamClean foamInstall foamOldDirs
Old   April 30, 2013, 04:11
Lieven
It just occurred to me that the environment variables probably get lost when you use 'sudo'.
So
$ sudo su -
$ cd /opt/openfoam210/
$ source etc/bashrc
$ Allwmake
will probably work.
However, if it goal is to compile a custom solver, I would strongly recommend you to put it somewhere in the home-directory and not in the /opt/openfoam210 - folder so you can compile it without the sudo-command. This will cause problems at a later stage (check out http://www.cfd-online.com/Forums/ope...und-error.html )
Cheers,
L
Old   April 30, 2013, 08:17
Galchenko Olga
It workes!!!!!
Thanks a lot) Your help was really irreplaceable!
Regards, Olga
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 03:09
Unexplained Error during Solver Runs cfb CFX 6 November 9, 2012 16:42
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
