April 16, 2013, 17:52 |
cyclic boundary conditions for FSI
Kanuk
Rep Power: 15 |
Hi All,
I've found out that the current 1.6-ext doesn't support cyclic boundary conditions for adaptive mesh motion (i.e. FSI). As such, I've spent a bit of time trying to figure out how to get around this issue.... At this point, I'm stuck and would really appreciate any insight into my problem. I *think* I'm fairly close, and have based my library off of what's found in src/tetDecompositionFiniteElement. Allwmake runs fine, no complaints. However, when I include the relevant libs in my controlDict I get the following error: Code:
... // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load /home/dave/OpenFOAM/dave-1.6-ext/lib/linux64Gcc46DPOpt/libfaceDecompTetCyclic.so: undefined symbol: _ZTIN4Foam28cyclicTetPolyPatchFaceDecompE --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load /home/dave/OpenFOAM/dave-1.6-ext/lib/linux64Gcc46DPOpt/libcellDecompTetCyclic.so: undefined symbol: _ZTVN4Foam28cyclicTetPolyPatchCellDecompE Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: laplaceFaceDecomposition --> FOAM FATAL ERROR: Unknown faceTetPolyPatchFaceDecomp type cyclic. Valid faceTetPolyPatchFaceDecomp types are : 7 ( wall processor wedge patch empty ggi symmetryPlane ) From function faceTetPolyPatchFaceDecomp::New(const polyPatch&, const tetPolyBoundaryMeshFaceDecomp&) in file tetPolyMeshFaceDecomp/tetPolyPatches/faceTetPolyPatch/newFaceTetPolyPatchFaceDecomp.C at line 59. FOAM exiting Cheers, Dave |
April 17, 2013, 03:55 |
#2 | |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi David,
In the beginning of your run, it tells you the following: Quote:
Kind regards Niels |
April 17, 2013, 16:02 |
Kanuk
Rep Power: 15 |
Thanks Niels for your input.
After checking, I indeed did find the undefined symbols in my user libbin: Code:
$ nm -u $FOAM_USER_LIBBIN/libCyclicBC* | grep cyclic U _ZN4Foam15cyclicPolyPatch8typeNameE U _ZTIN4Foam15cyclicPolyPatchE U _ZTIN4Foam28cyclicTetPolyPatchCellDecompE U _ZTVN4Foam28cyclicTetPolyPatchCellDecompE U _ZN4Foam15cyclicPolyPatch8typeNameE U _ZTIN4Foam15cyclicPolyPatchE U _ZTIN4Foam28cyclicTetPolyPatchFaceDecompE U _ZTVN4Foam28cyclicTetPolyPatchFaceDecompE Code:
$nm -u $FOAM_LIBBIN/libfaceDecompFiniteElement.so | grep processor U _ZN4Foam18processorPolyPatch8typeNameE U _ZTIN4Foam18processorPolyPatchE |
April 18, 2013, 01:30 |
Rep Power: 37 |
Hi David,
I will give your code a try myself later today (if the time allows), so could you tell me, what solver you have been using? I have a vague feeling of the reason for your problems, but it is too vague for me to put in words Kind regards Niels |
April 18, 2013, 04:55 |
Rep Power: 37 |
Hi David,
I can reproduce the error, if I am using moveDynamicMesh. On the other hand, if I use a small tool for mesh motion, which I made myself, then it does recognise your cyclic boundary condition and subsequently crashes with another error I have tried looking around and changing the include-statements and the linking properties of moveDynamicMesh.C and Make/options, though, I have not been able to isolate the problem. Though, if I were you, I would start to add a lot of include-statements related to the tetFem-framework to the solver, which you are using and test, whether this resolves your problem. I can unfortunately not share my successful code with you, as it hinges on a large internal development project. Kind regards Niels |
April 19, 2013, 03:36 |
Rep Power: 37 |
Hi David,
It occurred to me that my include statements in the project development could be helpful. Below are those related to the 1.6-ext release; all includes related to the project have been removed: Code:
#include "addToRunTimeSelectionTable.H" #include <algorithm> #include "autoPtr.H" # include <cassert> #include "cellSet.H" #include "cellZone.H" #include "coordinateSystem.H" #include "cyclicFvPatch.H" #include "displacementFvMotionSolver.H" #include "dynamicFvMesh.H" #include "edgeInterpolationScheme.H" #include "elementFields.H" #include "faceTetPolyPatchFaceDecomp.H" #include "faCFD.H" #include "faMesh.H" #include "fieldTypes.H" #include "fixedValueFvPatchFields.H" #include "fixedValuePointPatchFields.H" #include "fixedValueTetPolyPatchFields.H" #include "fvCFD.H" #include "fvcMeshPhi.H" #include "fvMesh.H" #include "fvMeshSubset.H" #include "fvPatchField.H" #include "fvPatchFieldMapper.H" #include "fvPatchFields.H" #include <gsl/gsl_matrix.h> #include <gsl/gsl_multiroots.h> #include <gsl/gsl_vector.h> #include "hydrodynamicProperties.H" #include "incompressible/RAS/RASModel/RASModel.H" #include "interpolateXY.H" #include "IOdictionary.H" #include "IOList.H" #include "lduMatrix.H" #include "mapPolyMesh.H" #include "mathematicalConstants.H" #include "mixedFvPatchFields.H" #include "motionDiff.H" #include "objectRegistry.H" #include "pointPatchFields.H" #include "polyMesh.H" #include "regIOobject.H" #include "runTimeSelectionTables.H" #include "scalarSquareMatrix.H" #include "SortableList.H" #include "subCycle.H" #include "surfaceFields.H" #include "Switch.H" #include "tetDecompositionMotionSolver.H" #include "tetFec.H" #include "tetFem.H" #include "tetFemMatrices.H" #include "tetFemMatrix.H" #include "tetPointFields.H" #include "tetPolyMesh.H" #include "tetPolyMeshMapper.H" #include "tetPolyPatchFields.H" #include "Time.H" #include "Tuple2.H" #include "uniformDimensionedFields.H" #include "volFields.H" #include "wallFvPatch.H" #include "wallPolyPatch.H" Niels |
April 19, 2013, 14:54 |
Kanuk
Rep Power: 15 |
Hi Niels,
Thanks for providing your included header files! Unfortunately though, after including them in my solver (icoFsiFoam) I still end up with the same error as stated previously. And, without a more verbose error message (and my limited c++ experience) it may take awhile to find where the problem is... Regardless, I'm still looking into it. Will let you know if I come up with anything. Cheers Dave |
April 25, 2013, 14:29 |
Kanuk
Rep Power: 15 |
It's a shot in the dark, but here's a newer version of the cyclic BC. Basically I replaced a few member functions from the processor type BC with the ones needed for the cyclic type BC, and with some changing of class names, it still compiles fine.
Unfortunately though, I still get the same error message about undefined symbols. I was hoping it worked for your case though, Niels... Like I said, likely this is a no. But maybe worth a try. cyclicBC_V2.tar.gz |
May 3, 2013, 03:28 |
#9 |
Rep Power: 37 |
Hi David,
I am sorry that I have not answered before, though, I have been busy and will also be so in the coming time, thus I do not think that I will have time to take a look on the code. Good luck, Niels |
March 7, 2014, 03:44 |
#10 |
Rep Power: 12 |
I am struggling with the same case, need to use cyclicGgi BCs, you got any solution on that?
April 25, 2014, 02:52 |
#11 |
Jiri
Rep Power: 13 |
Do you have an example for cyclic BC of a rotating segment of rotor domain, just an example..
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
snnappyHexMesh with cyclic boundary conditions | longamon | OpenFOAM | 2 | May 9, 2011 12:28 |
periodic and cyclic boundary conditions | Hadi | Main CFD Forum | 2 | June 29, 2007 07:19 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
