Problem between rhoLTSPimpleFoam and mesh.update(); |
April 10, 2013, 01:04 |
HECKMANN Frédéric
Rep Power: 17 |
Dear All,
I've modified the rhoPimpleFoam solver (OF2.2) to add a mesh morphing. It is a very small node displacement (1/10 of the first cell height) so I didn't setup the absolute phi. With the rhoPimpleFoam solver, everything goes well. However, if I apply the same modification to the rhoLTSPimpleFoam, it doesn't work anymore. I get an error about dimensions which seems to come from a rho factor (kg.m-3 missing). I've found that if I remove "mesh.update();" from my solver, it works perfectly. Then, I found that the error comes from the "pEqn.H" and more precisely from the phid calculation. Has anyone an idea of the origin of the problem ? It seems to come from the localEuler scheme but I can't identify the source. Thx, Fred Edit: If I set the ddt scheme to Euler, my simulation runs smoothly. However, with a localEuler, the simulation crash during the first iteration. Origine of the Error Code:
surfaceScalarField phid ( "phid", fvc::interpolate(psi) *( (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, rho, U, phi) ) ); Code Error: Code:
--> FOAM FATAL ERROR: LHS and RHS of + have different dimensions dimensions : [0 3 -1 0 0 0 0] + [1 0 -1 0 0 0 0] From function operator+(const dimensionSet&, const dimensionSet&) in file dimensionSet/dimensionSet.C at line 458. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:? #3 Foam::tmp<Foam::GeometricField<Foam::typeOfSum<double, double>::type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator+<double, double, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:? #4 at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 at ??:? Aborted (core dumped) |
April 10, 2013, 03:59 |
HECKMANN Frédéric
Rep Power: 17 |
Finally I can answer my question.
The problem comes from the fact that mesh.update() turns mesh.moving() to be true (no surprise here). The problem is located in the "localEulerDdtScheme.C" in src/finiteVolume/finiteVolume/ddtSchemes/kicakEulerDdtScheme. The scheme ddtPhiCorr() is simply not implemented for a compressible solver having the mesh moving. There is a "if (mesh().moving())" leading to a single scheme which is only suitable for incompressible solver. However, if mesh().moving()=false, the scheme has 3 choices depending of the dimension of phi and U. To solve my problem I've simply decided to ignore the mesh motion ! indeed, my displacement is of about 1e-7 meter per time step (which are 1e-3 second) where my first cell height is about 1e-4. To do so, only add: "mesh.moving(false);" after your "mesh.update();". With this code, the following solver think that the mesh is steady and so it doesn't compensate the motion of the boundary/mesh (which is wrong but acceptable for very small displacement). |
Problem with inconsistent patches (AMI, interDyMFoam) | jrrygg | OpenFOAM Running, Solving & CFD | 3 | February 1, 2013 03:23 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 15:24 |
MPI comunication wrong after use of gather/scatter | matteoL | OpenFOAM | 1 | October 10, 2011 13:19 |
mesh.update problem in a new FSI solver | ICL | OpenFOAM | 0 | October 8, 2011 14:16 |
the problem about"Max(gamma)>1" | zhajingjing | OpenFOAM | 6 | April 5, 2010 02:33 |
