Wrong figure in Hrv. thesis?
Old   April 6, 2013, 04:05
Default Wrong figure in Hrv. thesis?
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi there, a few days ago Dr. Axel Larreteguy told me about some concerns about Figure 3.7 in Hrv. thesis (see attachment). Here we have the vectors \vec{\Delta} and \vec{S}, which have units of area and then vector \vec{k}, the correction, which seems to take in account the displacement of \vec{\Delta} from the face centroid b, so that it has units of distance. The concerns are:
1. Why the differences in units?
2. Do the vector decomposition make sense as is drawn?
Below the figure it is stated that vector \vec{k} is not used
3. The correction vector is not used because simplification or because it is zero (I guess so)?
Following the work of Mathur and Murthy
http://www.tandfonline.com/doi/abs/1...915105#preview
it leads to a zero correction. If it is the wrong interpretation
4. How do we interpret the figure?
Thanks in advance,
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 6, 2013, 15:53
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Thanks in advance,
Not sure if I can answer your questions, but
In Hrv's thesis (and in OpenFOAM), non-orthogonal correction is not employed on the boundary. This assumption is fine if we assume that phi does not vary along the boundary.
Although, if we assume that phi varies linearly along the boundary then non-orthgonal correction is required to maintain accuracy, as outlined in
E. De Villiers thesis (Fig. 4.7).
I believe that this correction is not performed in OpenFOAM because it may lead to mass flux across walls.
But boundary non-orthogonal correction can be employed through use of custom boundary conditions, such as fixedDisplacement (corrected version of fixedValue) in the solidMechanics branch of OpenFOAM-1.6-ext.
Hope it helped,
Philip
bigphil is offline   Reply With Quote
Old   April 7, 2013, 02:37
Thanks Philip, it helped! I'm going to elaborate some ideas to post.
Regards.
Research Scientist
Urgent! how to plot contours without grid in the figure? ivanbuz FLUENT 11 November 10, 2009 22:44
Abt: Schlieren figure in Tecplot using data jinwon park Tecplot 2 December 27, 2007 07:48
Latex questiuon (figure) John Dongarra Main CFD Forum 5 August 22, 2007 11:06
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 11:38
How can I post a figure on this forum? ZHU Main CFD Forum 3 June 21, 2000 23:22
