How to? Extra term in k-e equation. Implicit-Explicit
Old   March 15, 2013, 08:48
Default How to? Extra term in k-e equation. Implicit-Explicit
M. Montero
be_inspired is on a distinguished road
Hi all,
I am trying to implement a canopy model into OF.
With respect to the momentum equation, I am seeing several post where the code was similar to the following one:
// Solve the Momentum equation
UEqn() == -fvc::grad(p)-fvm::Sp(mag(fvc::Sp(Cd*canopydensity*canopyleaf,U) ),U)
The point is when I need to implement the extra terms in k and epsilon equation.
I have introduced the following ones:
// Turbulent kinetic energy equation
volScalarField Fk=0.8*canopydensity_*canopyleaf_*mag(U_)*mag(U_)* mag(U_);
tmp<fvScalarMatrix> kEqn
fvm::ddt(k_)
+ fvm::div(phi_, k_)
+ fvm::SuSp(-fvc::div(phi_), k_)
- fvm::laplacian(DkEff(), k_)
G
- fvm::Sp(epsilon_/k_, k_) + Fk
// Dissipation equation
volScalarField Fe=(epsilon_/k_)*Cpepsilon1_*Fk;
tmp<fvScalarMatrix> epsEqn
fvm::ddt(epsilon_)
+ fvm::div(phi_, epsilon_)
+ fvm::SuSp(-fvc::div(phi_), epsilon_)
- fvm::laplacian(DepsilonEff(), epsilon_)
C1_*G*epsilon_/k_
- fvm::Sp(C2_*epsilon_/k_, epsilon_) + Fe
It compiles correctly and I obtain some physical results, but I have just found a master thesis where:
fvm::ddt(epsilon_)
- fvm::Sp(fvc::div(phi_), epsilon_)
C1_*G*epsilon_/k_
+ fvm::Sp(Cd_*alphaL_/k_*(CEps4_*betap_*pow(mag(U_),3)-CEps5_*betad_*k_*mag(U_)), epsilon_); //Source Term)
fvm::ddt(k_)
- fvm::Sp(fvc::div(phi_), k_)
G
+ fvm::Sp(Cd_*alphaL_/k_*(betap_*pow(mag(U_),3)-betad_*k_*mag(U_)), k_); //Source term)
The question are:
Is correct my implementation?
what is the advantages to take the extra terms as implicit in the k and epsilon equation with respect to take them as explicit terms? Quick Convergence? Stability?
Thank you very much for your time.
be_inspired is offline   Reply With Quote
Old   March 19, 2013, 11:50
M. Montero
Ok, It seems according to the other topic that it is related to the stability of the equations...
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
Source term energy equation for reactive flows DaIN Main CFD Forum 0 October 6, 2011 16:11
Large source term in species equation MACFD FLUENT 4 January 4, 2011 15:16
Extra term in Epsilon equation Valdemir G. Ferreira Main CFD Forum 0 April 30, 2000 09:57
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
