Access to turbulence values in my own solver
Old   March 14, 2013, 05:19
Default Access to turbulence values in my own solver
sfigato's Avatar
Marco Longhitano
sfigato is on a distinguished road
Send a message via Skype™ to sfigato
Dear Foamers,
I am building my own OpenFOAM solver by modifing the interPhaseChangeFoam. I want to add a new model. I want to get acces to the value of turbulence kinetic energy inside that model. In order to fix this issue, I have tried to follow many threads as:
http://www.cfd-online.com/Forums/ope...k-epsilon.html
http://www.cfd-online.com/Forums/ope...-low-re-3.html
Nevertheless, noone of them helped me to fix it!
I would like to have access to the actual values of for instance k-omega SST variables, but I would like to understand how do I generally find out where certain variables are computed and how to access them?
Can anyone explain me this issue?
Regards
Marco
sfigato is offline   Reply With Quote
Old   March 14, 2013, 05:49
Bernhard
Bernhard is on a distinguished road
This link may be helpful:
http://openfoamwiki.net/index.php/Op...objectRegistry
Also, I think this post covers your basic needs:
http://www.cfd-online.com/Forums/ope...tml#post254591
Bernhard is offline   Reply With Quote
Old   March 14, 2013, 06:08
sfigato's Avatar
Marco Longhitano
Dear Bernhard,
I have already read these links! Since I am quite new with OpenFoam programming I could not fix my problem!
I try to explain it in deepen it :
I would like to use the value of turbulence kinetic energy in my model SchnerrSauer.C (interPhaseChangeFoam)..so I have tried to add to SchnerrSauer.C the following lines:
Foam::tmp<Foam::volScalarField>
Foam::PhaseChangeTwoPhaseMixtures::SchnerrSauer: Coeff
const volScalarField& p
const
volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
volScalarField rho
limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2()
return
const volScalarFieldField& turbulence->k() = db().lookupObject<volScalarField>("turbulence->k()");
(3*rho1()*rho2())*sqrt(2/(3*rho1()))
*rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat()));
and I got this error message:
SOURCE=phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/transportModels -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/transportModels/incompressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/turbulenceModels/incompressible/turbulenceModel -IphaseChangeTwoPhaseMixtures/phaseChangeTwoPhaseMixture -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SchnerrSauer.o
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff(const volScalarField&) const’:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:110:5: error: expected primary-expression before ‘const’
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:110:5: error: expected ‘;’ before ‘const’
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:110:11: error: ‘volScalarFieldField’ does not name a type
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:114:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Fehler 1
Hera are the two files of the model
Thanks in advance
Regards
Marco
Old   March 14, 2013, 06:15
Bernhard
First you get an error because of the return above the bold line.
Following the second link, I would guess that you can access k by:
const volScalarFieldField& k = db().lookupObject<volScalarField>("k");
turbulence->k() is only how it is called inside the solver, because you construct a turbulence model with a reference to k.
Old   March 14, 2013, 06:22
sfigato's Avatar
Marco Longhitano
Thanks for the quick reply!
I add the line in this way:
const
volScalarField rho
const volScalarField& k = db().lookupObject<volScalarField>("k");
return
ana I got this error:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:107:11: error: ‘volScalarField’ does not name a type
Maybe, I did not understand where I must add this line..in order to get acces to k value for all the model files!
Regards
Marco
Old   March 14, 2013, 06:27
Bernhard
Probably you need to include a few files in the header of your files. I am not exactly sure which, but maybe you can find it in a few examples?
Old   March 14, 2013, 06:32
sfigato's Avatar
Marco Longhitano
Dear Bernhard,
sorry but I had a type mistake. It is working in your way!
How can I be sure that this 'k' is the turbulence kinetic energy?
The code compiles for another variable name too (for example if I reply 'k' with 'm')
Regards
Marco
Old   March 14, 2013, 06:36
Bernhard
Try to run it with both variables names. Also, you can copy the contents to a new volScalarField and write it to disk, then compare.
Old   March 14, 2013, 07:36
sfigato's Avatar
Marco Longhitano
I am pretty sure that turbulence kinetic energy is named by turbulence->k()...the question is How can I use it inside my model (which is used to get the source term in a n equation inside the solver)!
I obviously include #include "turbulenceModel.H".
I am sorry again if i do not understand but I do not know so well C++!
Greets
Marco
Old   March 14, 2013, 07:58
Bernhard
This is actually not true. If you look in the source code of, for example, the kEpsilon model, you will find
 95     k_
 96     (
 97         IOobject
 98         (
 99             "k",
100             runTime_.timeName(),
101             mesh_,
102             IOobject::NO_READ,
103             IOobject::AUTO_WRITE
104         ),
105         autoCreateK("k", mesh_)
106     ),
This is no different then the volScalarFields that are created in the createFields.H of your solver.
turbulence->k() is just to call the member function k() of your object turbulence (which via an intelligent way is of the class kEpsilon). It does not do a lot more than returning this volScalarField.
137         //- Return the turbulence kinetic energy
138         virtual tmp<volScalarField> k() const
139         {
140             return k_;
141         }
Also, if you open your 0/k file, you will probably see something like
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
Thus, the name is k, and turbulence->k() is just a way to call it.
This all is by the way relatively straightforward C++. I encourage you to learn the C++ (until you understand classes and pointers)
Old   March 14, 2013, 08:18
sfigato's Avatar
Marco Longhitano
Dear Bernhard,
First of all, thanks for the reply. If I understand from your post the name 'k' refers to the turbulence kinetic energy. Moreover, the only way tu use it in my model is what you have adviced to me:
I am following your hint to learn more about C++ (but it si not a easy task for me)!
The last question and I promis that I do not disturb you anymore..
It is enough the line that I added to use the turbulence kinetic energy or I must modify somelse in side the ScnerrSauer.H file or inside the model itself?
For example to use pressure value inside the model*1..it is by default:
I thank you for you kindness.
Greets
Marco
*1 Maybe it si not true!
Old   March 14, 2013, 08:21
Bernhard
Yes, that is the only. You do not have an object turbulence inside the model. This is only constructed in the solver.
In the other case, a pointer to the pressurefield is passed to the model via constructor functions. If you want to change that, you also have to change the way that the constructor is called. In general, this is not what you want to do.
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
CFX solver workspace properties: modify default values zboud CFX 2 March 8, 2010 09:10
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
