Sources of help getting started in OpenFoam: nonisothermal viscous compressible 2D?
Old   February 8, 2013, 11:51
Default Sources of help getting started in OpenFoam: nonisothermal viscous compressible 2D?
bzz77 is on a distinguished road
Hello everyone:
I work in C++, but have never used OpenFoam. I have played around with it and it seems feasible to start. There's a particular problem I'd like to address, that I will probably work on for many months. Because of time constraints, I'd like to get some help in setting up the problem:
I am interested in modelling unsteady viscous nonisothermal compressible flow in 2D, with variable transport properties. I would eventually like to model two-phase flow (gas and liquid).
Does anyone know if there is reliable, relatively affordable help out there for setting up this kind of thing in OpenFoam? Or maybe someone has already worked on such a code?
I know there are certain complications in dealing with the kind of problem I'm interested in. I have worked with isothermal, constant-viscosity flows in the past, but have never achieved this level of complexity. So I'd be interested in getting some direction in this regard.
Thanks a lot for any suggestions.
bzz77 is offline   Reply With Quote
Old   February 9, 2013, 18:54
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Originally Posted by bzz77 View Post
Hello everyone:
Hello and welcome,
I am not very familiar with your problem but I think you can start with something like compressibleInterFoam. A list of available standard solvers can be found in:
http://www.openfoam.org/docs/user/standard-solvers.php
Other community developed solvers can be found in the extend project:
http://www.extend-project.de/
Most likely you need to combine capabilities from different solvers. With a background in C++ you will be ready to hack your way through the Doxygen manual. Good luck!
Hisham
Hisham is offline   Reply With Quote
compressible flow, openfoam, polymer, viscous flow
Newbie to compressible, viscous flow. Advice on approach to problem? bzz77 Main CFD Forum 4 December 4, 2012 08:59
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 12:46
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
Interpolation scheme for characteristic upwind for compressible flow enok OpenFOAM Running, Solving & CFD 0 May 8, 2006 15:37
Compressible Viscous Code vaidation test cases? Mohammad Kermani Main CFD Forum 2 November 11, 1999 15:22
