problem while defining a new volScalarField in a new turbulence model |
January 24, 2013, 03:44 |
Nikesh Bhattarai
Rep Power: 14 |
Hii Foamers,
I am working on a new turbulence model which utilizes the basic Governing Equations of LaunderSharmaKE model. I need to modify the expression for nut. While doing so, I make use of a new term, k2e (it is a name i have given to this new variable, where k2e = sqr(k_)/epsilonTilda_ ) and in one part of the code it requires me to solve for div(phi_,k2e). I could implement all the equations and expressions in the new source code and I could also compile it successfully. But when I try to run a case using that scheme, I get an error message:: --> FOAM FATAL IO ERROR: [4] [8] keyword div(phi,(sqr(k)|epsilon)) is undefined in dictionary "/home/users/nikesh/Work/mvg/2-3Dflatplate-test/processor8/../system/fvSchemes::divSchemes" I get the idea that this error is asking me to define the div(phi,k2e) term in the system/fvScheme file. I did that too. Under the divSchemes I included div(phi,k2e) Gauss upwind And I still get the same error! Any help is highly appreciated. Thanks!! nikesh |
January 24, 2013, 12:25 |
Rep Power: 15 |
Hi Nikesh,
Include the exact keyword in your fvSchemes, so: div(phi,(sqr(k)|epsilon)) Gauss upwind; That should do it. |
January 24, 2013, 21:35 |
Nikesh Bhattarai
Rep Power: 14 |
Thnx blacksquirrel!
I had tried that option too but still wouldn't work. However good news that I managed to sort it out in another way. I constructed and defined the function k2e_ in the source code.C file as:: k2e_ ( IOobject ( "k2e", runtime_.timeName(), mesh_, IOobject::MUST_READ, IOobject::AUTO_WRITE ), sqr(k_)/epsilonTilda_ ), I also declared it in the header (source_code.H) file as:: volScalarField k2e_; The expressions were then implemented and used in the part where viscosity is calculated. And hence in the system/fvSchemes file, I could use:: divSchemes div(phi,k2e) Gauss upwind; I appreciate your reply though!! Cheers!! |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 03:08 |
Problem with turbulence model | akonduri | OpenFOAM | 2 | September 17, 2010 01:49 |
Turbulence model for mixing problem??? | nileshjrane | Main CFD Forum | 7 | September 14, 2010 05:57 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
Fan heater model: what turbulence source to use? | andy20 | Main CFD Forum | 0 | March 2, 2008 13:46 |
