September 17, 2013, 07:52 |
#21 |
Rep Power: 13 |
Ah I see. Would be very great to use it! I also got now the meaning of beta and I've rewritten the simpleLiquid to the tait-Equation of state:
rho=rho_0*((p+B)/(p_0 +B))^(1/gamma); gamma=7.15 B = prefactorA + prefactorB*T[°C] + prefactorC*T²[°C²] psi = d rho/d p rhoHat not used (set to scalar(1.0)). B is calculated in thermoCorrection(), rho and psi are calculated in psiCorrection() But it's not very stable and I don't know why... it does not seem to exceed the courant numbers... Anyway, for sufficiently small starting values for my bubble (r=160mum, alpha=0, T_0<600K, p_rgh_0<4e6Pa) the picture really looks like something expected. More than with any solver before. So it would be really great to get your update soon! Are you going to change the solver routines or the equations? |
October 30, 2013, 09:48 |
#22 |
weiyi xue
Rep Power: 13 |
Hi Matvej,
Thanks for your great job. I am looking for the solver that is compatible with openfoam2.2.x. If you complete a porting of version. please publish it on this site. Thanks Simon |
November 1, 2013, 05:55 |
#23 |
weiyi xue
Rep Power: 13 |
Sorry, I had a very simple question. Regarding tutorial water-flashing, I think that phase2 is atmosphere and rho of phase2 should be set to 1 in file transportProperties. I could not understand why rho of phase2 is set to 0.1 in transportProperties.
Thanks in advance. Simon |
January 22, 2014, 18:13 |
#24 |
Jace
Rep Power: 16 |
just out of curiosity... you mentioned that the governing equations have been rewritten along with other significant changes to the solver. Do you mind briefly touched upon what exactly are the improvements, and what are the motivations behind them. I assume there's some flaws in the previous set of governing equations? Thanks! Jason |
January 24, 2014, 05:13 |
#25 |
Phoevos
Rep Power: 17 |
I tried to test the new solver (successfully compiled from provided source code for OpenFOAM 2.1.x) on one of the tutorial cases, but it does not work. I tried to run the hemispherical body (http://openfoamwiki.net/index.php/Co...haseChangeFoam, case 1), but it always diverges at some point at 70ms. I tried to run with constant time step and at 69ms Courant No blows up. I switched to auto-timestepping with max. Co. 0.05, it goes a little bit further, but still crashes. Has anyone managed to run this particular case for 20s (or more), as it is in the controlDict? Generally, when running I notice that there are significant oscillations in pressure field and I also get phase change (cavitation) at the slip wall, which does not seem reasonable... I have not modified any of the tutorial settings or the solver itself... Any ideas on that? Thanks in advance. |
March 19, 2014, 11:48 |
#26 |
Juan Carlos
Rep Power: 16 |
Hi Matvej,
I would like to use your solver for compressible two-phase flow with phase change, and I would like to know if the new version of this solver for version OF2.2.X it's available Thank you in advance for sharing your work Best Regards Juan C. |
April 24, 2014, 15:50 |
Follow-up
#27 | |
Joseph Prince
Rep Power: 12 |
Were you ever able to finish this solver?
Thanks, Quote:
January 5, 2015, 11:17 |
#28 |
Christian
Rep Power: 12 |
Hi Marco,
any news on the hydraulic resistance test case? I would like to test it as well! Also, having the solver for OF2.2.x would be great |
April 1, 2015, 19:49 |
#29 | |
zhouhoucun
Rep Power: 12 |
Yours, Zhou |
July 21, 2015, 11:04 |
#30 |
Rep Power: 16 |
Hi All,
I would like to use the code as well but I could not find it. Is the code still available? Thanks! |
October 16, 2015, 03:50 |
#31 |
Federica
Rep Power: 11 |
Hi matvey.
I am not able to reach the page for the download. The solver is still available? Can I implemeted it in OpenFOAM-2.3? Thank you Federica |
January 14, 2016, 09:39 |
Link for download
#32 | |
Bjorn H. Hjertager
Rep Power: 17 |
Hi, It seems that the link to downloading the code is wrong. Is it possible to get an updated link for downloading? Kind regards Bjorn |
January 15, 2016, 10:35 |
Link for downloading the code from Matvey Kraposhin
#33 |
Bjorn H. Hjertager
Rep Power: 17 |
It seems that the link for downloading this code is inactive. Does anybody in this thread have any infomation on how to download the code from Matvey Kraposhin mentioned in his post? Kind regards Bjørn |
January 17, 2016, 21:29 |
#34 |
popovich
Rep Power: 10 |
It seems that the link to downloading the code is wrong. Is it possible to get an updated link for downloading? Kind regards popovich |
July 22, 2016, 00:11 |
Singhal and Zwart model
#35 | |
zhouhoucun
Rep Power: 12 |
I also implemented the Singhal and Zwart cavitaiton model into interPahseChangeFoam solver, and I tested these two model with the 2D NACA66 hydrofoil, unfortunately,they gave the wrong results, can you share you code, or I can send my code to your email box? My email address is 470861844@qq.com. Thanks you. Houcun |
January 9, 2018, 00:21 |
#36 |
Hz Lin
Yeah I am trying to work on similar problems, and found this potentially very helpful. Like many others, I noticed the download is not available anymore. Does anyone have access to it? Thanks in advance.
July 19, 2021, 04:22 |
#37 |
Abhishek Singh
Hello Matvey! It has been a long time but can you please share recent developments of your solver?
July 19, 2021, 04:23 |
#38 |
Abhishek Singh
Hello Matvey! It has been a long time but can you please share the recent developments of your solver?
August 6, 2021, 10:24 |
#39 |
L S
Rep Power: 10 |
Can you please share the solver compressibleMixingPhaseChangeFoam? I need to solve problem related to heat pipe. Looks like the solver has been removed from all the links. If you have a copy, please share with me at silviliril@gmail.com
July 15, 2023, 06:43 |
#40 |
Viktor
Rep Power: 6 |
Hello! It has been a long time, but can you please share exampleCase of this solver? If you have a copy, please share with me at asenya7@yandex.ru
Modelling Supersonic TwoPhase Flow with Phase Change | wes | OpenFOAM Running, Solving & CFD | 9 | July 27, 2021 12:05 |
Multiphase flow and Phase change due to heat transferevaporation | haghajani | OpenFOAM Running, Solving & CFD | 88 | February 11, 2020 09:00 |
phase change modeling | Danial Q | Main CFD Forum | 0 | April 5, 2012 02:14 |
low speed compressible flow | lily | CFX | 2 | November 16, 2005 06:15 |
Two phase flow models | Atholl | Main CFD Forum | 2 | May 7, 2002 04:49 |
