November 23, 2012, 17:23 |
Error concerning rDelatT
Azorica
Hello everybody,
I am trying to modify the coalChemistryFoam to an LTScoalChemistryFoam. I have followed the example of reactingFoam - LTSreacting Foam. This is however the first solver modification I am operating, so don t know if I am doing it right or wrong. I have mange to compile the new solver, but when I try to run the test case I get the following error: --> FOAM FATAL ERROR: request for volScalarField rDeltaT from objectRegistry region0 failed available objects of type volScalarField are 20 ( psi N2 rho CO2 k O2 psi_0 H2 CH4 alphat alpha p T mut pDyn H2O rhoEffLagrangian mu hs epsilon ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/imagda/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131. FOAM aborting I have created a volScalarField rDeltaT in CreateFileds. h, but I get the same error when I run the case. Does anybody has any idea how can I correct this. |
August 3, 2017, 15:39 |
#2 | |
Rep Power: 15 |
Cheers |
June 8, 2019, 09:31 |
Same Error
Sreekar Reddy S
Rep Power: 7 |
Hi
I am working with similar kind of error. Code:
--> FOAM FATAL ERROR: request for volScalarField kappa from objectRegistry region0 failed available objects of type volScalarField are 25 ( Kd rhok F C_0 alpha.liquid C.liquid rho C.solid ((alpha.solid*Cp)+(alpha.liquid*Cp)) min(max((Tmelt+(((Teut-Tmelt)|Ceut)*C)),Teut),Tmelt) Tsol min(max((Tmelt+(((Teut-Tmelt)|Calpha)*C)),Teut),Tmelt) p_rgh Tliq dFdT gh C alpha.solid rho_0 p T T_0 (((180|sqr(DAS))*pow(min(alpha.solid,0.95),2))|pow(max(alpha.liquid,0.05),3)) H alpha.liquid_0 ) From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file /home/sree/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 239. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&, bool) const in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" #3 ? in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" #4 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" #5 Foam::fv::EulerDdtScheme<double>::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::ddt<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" #7 ? in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/home/sree/OpenFOAM/sree-v1712/platforms/linux64GccDPInt32Opt/bin/scdccfFoam" Aborted (core dumped) Cheers |
