libforces - using calculated forces/moments in other library |
Andreas Wendy
Rep Power: 14 ![]() |
Hi everybody,
i want to use the calculated forces which i get by using the libforces.so to use in another library (ggi) how can i declare the variable for the forces and moments that i can use them for the ggi. i want to declare to moments global but i do not have a clue how to do it. i never worked with C++ before... hopefully you can help me. |
declare, forces, ggi, global, moments |
[Other] Multi species mass transport library [update] | novyno | OpenFOAM Community Contributions | 111 | November 9, 2021 23:37 |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
Forces not calculated when including a library in controlDict | fusij | OpenFOAM | 2 | May 13, 2011 07:25 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
Help! I cann't make library | Bowling | FLUENT | 5 | May 12, 2004 04:56 |
