modifying turbulentHeatFluxTemperature BC
Old   October 26, 2012, 15:16
Default modifying turbulentHeatFluxTemperature BC
Nikunj Raithatha
Nikunj.R is on a distinguished road
Hello All!
I am trying to use the turbulentHeatFluxTemperature BC to use with buoyantBoussinesqPimpleFoam solver, by replacing all the 'alphaEff' in the BC with 'kappaEff'. however, while doing so, I am getting the following error:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file heatFluxAFvPatchScalarField.C
could not open file RASModel.H for source file heatFluxAFvPatchScalarField.C
SOURCE=heatFluxAFvPatchScalarField.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/turbulenceModels -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/lnInclude -I/opt/openfoam211/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/turbulenceModel -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/heatFluxAFvPatchScalarField.o
heatFluxAFvPatchScalarField.C:30:22: fatal error: RASModel.H: No such file or directory
compilation terminated.
make: *** [Make/linuxGccDPOpt/heatFluxAFvPatchScalarField.o] Error 1
my Make/options file looks like this:
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/transportModels
LIB_LIBS = \
-lfiniteVolume
Please help me with the same.
Thanks,
Nikunj.
Nikunj.R is offline   Reply With Quote
Old   March 11, 2013, 21:25
Neilson Whit
wolfindark is on a distinguished road
Originally Posted by Nikunj.R View Post
Hello All!
Nikunj.
RASModel.H file cannot be linked by the compiler. Put the path of RASModel.H file into options file as like : -I$(LIB_SRC)/path/
may be you solved the problem long time ago, but I also work on these issues nowadays...
wolfindark is offline   Reply With Quote
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 05:56
modifying radial distribution function ravindra FLUENT 2 September 2, 2014 15:03
Modifying Gambit DBS file Created from MixSim 2 gkennedy3 ANSYS Meshing & Geometry 0 August 7, 2009 10:32
modifying Prepin File from command line pgopalak FLOW-3D 1 August 5, 2009 12:06
Modifying a mesh starting from case file Ale FLUENT 2 September 16, 2008 13:10
