Problems solving T Equation in separated flow using a second Order Closure Model
Old   October 25, 2012, 15:09
Default Problems solving T Equation in separated flow using a second Order Closure Model
pascool is on a distinguished road
Hi everybody,
I am trying to simulate the flow over a heated backward facing step by means of a modified simpleFoam solver which uses a second order Closure Model for the turbulent heat fluxes. The model worked pretty well in the heated turbulent channel. But it doesn't work for the Backward facing step in combination with a RSM turbulence model such as the LaunderGibson. I did a pre-calculation based on the RSM model and Fouriers Law for the scalar fluxes.
I already tried different solver settings and schemes in the fvSolvers and fvSolutions file.
Currently the files look as follows:
|  \\    /   O peration     | Version:  2.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0.01;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0.1;
    k
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    epsilon
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    R
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    nuTilda
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0.1;
    T BICCG 1e-08 0.01;
SIMPLE
    nNonOrthogonalCorrectors 0;
relaxationFactors
    p               0.3;
    U               0.5;
    k               0.5;
    epsilon         0.5;
    R               0.5;
    nuTilda         0.5;
    T               0.3;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div(phi,T)      Gauss upwind;
    div((Dp&grad(p))) Gauss linear;
    div((S&grad(p))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    laplacian(((nu|0.7123)+(nut|0.86)),T) Gauss linear corrected;
    laplacian(kappaEff,T) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
The error message is as follows:
#0  Foam::error::printStack(Foam::Ostream&) in "/home/pascal/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/pascal/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/pascal/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/pascal/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
 at simpleFoam_YSC_q.C:0
 in "/home/pascal/OpenFOAM/pascal-2.1.1/platforms/linux64GccDPOpt/bin/simpleFoam_YSC_q"
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Any help appreciated!
Regards,
Pascal
pascool is offline   Reply With Quote
Old   November 19, 2012, 11:29
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Can you post your code and let us know what model you are using? This error message is pretty general and could be a number of things. I did this one in the past using another scalar flux model other than the gradient diffusion hypothesis.
chegdan is offline   Reply With Quote
convergence, error, openfoam, separation
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 03:18
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 06:36
