Problem in recompiling a turbulence model in OpenFoam 2.1.1
Old   October 1, 2012, 18:14
Default Problem in recompiling a turbulence model in OpenFoam 2.1.1
pascool is on a distinguished road
Dear all,
I'am new to OpenFoam and have to compile a turbulence model which was programmed for OpenFoam 1.6 into the current version OpenFoam 2.1.1.
I tried it according to the manual by chalmers, however without any success.
The error log states:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file example/example.C
SOURCE=example/example.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/example.o
example/example.C: In constructor ‘Foam::incompressible::RASModels::YWV_DY::YWV_DY(const volVectorField&, const surfaceScalarField&, Foam::transportModel&)’:
example/example.C:299:37: error: ‘epsilonSmall_’ was not declared in this scope
example/example.C: In member function ‘virtual void Foam::incompressible::RASModels::YWV_DY::correct()’:
example/example.C:447:21: error: ‘epsilon0_’ was not declared in this scope
example/example.C:482:35: error: conversion from ‘Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >’ to non-scalar type ‘Foam::volSymmTensorField {aka Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>}’ requested
example/example.C:490:35: error: conversion from ‘Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >’ to non-scalar type ‘Foam::volSymmTensorField {aka Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>}’ requested
example/example.C:492:35: error: conversion from ‘Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >’ to non-scalar type ‘Foam::volSymmTensorField {aka Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>}’ requested
example/example.C:540:17: error: ‘k0_’ was not declared in this scope
In file included from example/YWV_DY.H:35:0,
                 from example/example.C:29:
/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H: In static member function ‘static Foam::autoPtr<Foam::incompressible::RASModel> Foam::incompressible::RASModel::adddictionaryConstructorToTable<RASModelType>::New(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&) [with RASModelType = Foam::incompressible::RASModels::YWV_DY, Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>, Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]’:
/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:138:1:   instantiated from ‘Foam::incompressible::RASModel::adddictionaryConstructorToTable<RASModelType>::adddictionaryConstructorToTable(const Foam::word&) [with RASModelType = Foam::incompressible::RASModels::YWV_DY]’
example/example.C:48:1:   instantiated from here
/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:126:9: error: no matching function for call to ‘Foam::incompressible::RASModels::YWV_DY::YWV_DY(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&)’
/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:126:9: note: candidates are:
example/example.C:52:1: note: Foam::incompressible::RASModels::YWV_DY::YWV_DY(const volVectorField&, const surfaceScalarField&, Foam::transportModel&)
example/example.C:52:1: note:   candidate expects 3 arguments, 4 provided
example/YWV_DY.H:51:7: note: Foam::incompressible::RASModels::YWV_DY::YWV_DY(const Foam::incompressible::RASModels::YWV_DY&)
example/YWV_DY.H:51:7: note:   candidate expects 1 argument, 4 provided
/home/pascal/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:126:9: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/example.o] Error 1
Any help to fix that problem appreciated!
Many thanks, Pascal
pascool is offline   Reply With Quote
Old   October 2, 2012, 01:38
I hope that I almost fixed it. However, one error is still there:
The corresponding line in the code is:
volSymmTensorField bb = (b & b);
where b is a volSymmTensorField as well.
Does anybody have an idea how to get it work?
Pascal
Old   October 2, 2012, 03:35
treima is on a distinguished road
are you sure, that b & b is a symmetric tensor?
regards
treima
treima is offline   Reply With Quote
Old   October 2, 2012, 12:52
I'm not sure but it should since b is just a modification of the Reynoldsstress tensor
Old   October 2, 2012, 14:22
Bernhard
Bernhard is on a distinguished road
Counterexample: http://www.wolframalpha.com/input/?i...%7D%7D&x=2&y=6
Edit: Hmm, this is probably not the definition of the dot product of tensorfields?
Bernhard is offline   Reply With Quote
Old   October 2, 2012, 17:17
Retired Super Moderator
Bruno Santos
Greetings to all!
This comment of Treima triggered my attention! This was a bug that was fixed in OpenFOAM 2.1.x back in December: The dot-product operator for two SymmTensor's returns a SymmTensor instead of a Tensor
This is also fixed in 1.6-ext since around the same time.
If by any chance you guys do need the result of "b & b" to be symmetric, you can do it with this:
symm(b & b)
Best regards,
Bruno
Old   October 3, 2012, 13:03
with the suggestion of Bruno to include
symm(b & b)
the compilation and the turbulent model runs without any errors.
I think the problem was that in OpenFoam 1.5 for which the model was writeen (b & b) automatically returned a symmetric tensor, since b is symmetric. With the mentioned bugfix this is no longer automatically valid.
The post processing will show whether the model computes reasonable results.
Thanks,
Pascal
compile, openfoam, turbulence model
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
SAS Turbulence model in OpenFOAM Steven85 OpenFOAM 0 July 22, 2011 05:36
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Rotta's k-kL Turbulence model in OpenFOAM?? barath.ezhilan OpenFOAM 1 August 14, 2009 06:55
