Volume Average for magnitude U
Like Tree9Likes
Old   October 18, 2012, 07:06
Simon Arne
simpomann is on a distinguished road
I never actually did any kind of wiki entry but I will try to find time at the weekend!
Okay:
I did a sum of the area as well and compared it to paraView: 99.71% identical size.
I triple checked using the same data and I put more of the function objects in line and compared them to the results from paraView (they showed the same behaviour in pressure loss, but the values differ).
Now its time to learn about the sample utility (that I so far avoided).
And thanks again! I know that this is not self understanding and appreciate it.
simpomann is offline   Reply With Quote
Old   October 18, 2012, 08:07
Simon Arne
Next step:
I defined a sampleDict with a plane exactly like in the function object and made samples of U, magU, p.
Integrating the sampled surfaces in paraView leads me to 12 m/s, so different from the areaAverage provided by the function Object.
Maybe I defined something wrong in my use of the function object, but I have no clue.
Old   January 14, 2015, 13:26
Illya Shevchuk
linch is on a distinguished road
Hi Benhard,
Originally Posted by gschaider View Post
With the big brother of the simpleFunctionObjects: swak4Foam. Something like:
functions
  velAverage
     type swakExpression;
     functionObjectLibs
       "libsimpleSwakFunctionObjects.so"
     verbose true;
     variables (
        "totalV=sum(vol());"
     expression "vol()*mag(U)/totalV";
     accumulations (
        sum
That would be the volume-weighted average.
If I understood it correctly, vol() corresponds to mesh.V() in the OF. What would be the swak-alternative for mesh.C()? What I want to do is to calculate the center of mass
centerMass = fvc::domainIntegrate(rho*mesh.C()) / fvc::domainIntegrate(rho)
using function objects.
Is there any documentation containing all functions available in libsimpleSwakFunctionObjects.so and libswakFunctionObjects.so? I've tried to search for something like that, but found just small peaces in the Wiki and in the forum.
Best regards,
Ilya
linch is offline   Reply With Quote
Old   January 14, 2015, 15:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by linch View Post
Hi Benhard,
Best regards,
Ilya
The equivalent for mesh.C() would be pos()
The only reference documentation of swak4Foam (that I know of ) is the "Incomplete reference Guide" that comes with the sources. Expressions are fully documented. Also some other things but no listing of the functionObjects is yet present. This readable version is linked from the swak-page on the Wiki http://sourceforge.net/p/openfoam-ex...amReference.md
linch and sourav90 like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
