Need Confirmation - Eulerian solver for tiny particules
Old   August 29, 2012, 11:26
Wink Need Confirmation - Eulerian solver for tiny particules
HECKMANN Frédéric
fredo490 is on a distinguished road
Hi everyone, it would be nice if somebody can give me some confirmations on the general aspect of my algorithm and the "code" that follows (especially the translation of the equations). I want to setup an unsteady Eulerian solver to compute the behavior of tiny particles in a fluid (only the fluid impact the particules motion through the drag).
Nomenclature :
- \alpha volume fraction of the particles
- \vec{u} velocity of the particles
- f(Re) function of the relative Reynolds number
- \tau time respond of the particle
- \vec{V} velocity of the fluid
Continuity equation :
\frac{\partial \alpha}{\partial t} + {\nabla \alpha \vec{u}} = 0
Momentum equation
\frac{\partial \alpha \vec{u}}{\partial t} + {\nabla \alpha \vec{u} \vec{u}} = \frac{f(Re)}{\tau } \alpha (\vec{V} -\vec{u})
The algorithm I have in mind :
1) setup a "phi_alpha" flux equal to \alpha \vec{u}
2) initialize this flux in the createfield with:
"linearInterpolate(alpha)*linearInterpolate(u) & mesh.Sf()"
3) solve the continuity equation using the following code:
fvScalarMatrix cEqn
fvm::ddt(alpha)
+ fvc::div(alpha_phi)
cEqn.solve()
4) update the flux phi_alpha with:
alpha_phi -= cEqn.flux();
5) compute the relative Reynolds number, the function f(Re) and \tau
6) solve the momentum equation using:
fvVectorMatrix uEqn
fvm::ddt(alpha, u)
+ fvm::div(alpha_phi, u)
fRe / Tau * alpa * (V – u)
uEqn.solve()
My questions are:
i) I'm not sure of the step 4... I kind of reproduce the simpleFoam code. Is there any documentation somewhere about the command ".flux" ?
ii) I'm not sure of the translation of the momentum equation step 6. Do I need to use a specific formulation for the source term ? Does the solver identify the last "u" by itself ?
Thank you in advance for reading this.
fredo490 is offline   Reply With Quote
Old   September 13, 2012, 03:24
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
have a look into twoPhaseEulerFoam or bubbleFoam and the thesis of H. Rusche. They all deal with a Eulerian formulation of two-phase fluid flows.
I would recommend to get into bubbleFoam or twoPhaseEulerFoam and remove everything you don't need. Particles with constant diameter and only drag as momentum exchange should not be a big problem.
Last edited by GerhardHolzinger; September 13, 2012 at 03:27. Reason: added clarifiaction
GerhardHolzinger is offline   Reply With Quote
equations, euler, particles
interfacing a fluid solver with abaqus Tuhin Rakshit Main CFD Forum 0 June 16, 2005 11:03
Could you comare StarCD with CFX 5?Help, please... Suteh CFX 54 November 7, 2001 21:12
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
Error during Solver cfd guy CFX 4 May 8, 2001 07:04
