calling janaf coefficients
Old   August 13, 2012, 16:51
Post calling janaf coefficients
sebastien vilfayeau
sebastien_F1 is on a distinguished road
I'm working on fireFoam, OpenFoam and I try to implement a new model. For this model, I need to have access to polynomial Janaf coefficients defined in "constant/thermo.compressibleGas".
My solution was to use a dynamic cast inside my code as follows :
const specieThermo<janafThermo<perfectGas> >& janaf_
dynamic_const<const specieThermo<janafThermo<perfectGas> >&>(thermo_)
And after to call those coefficients with member functions in janafthermo, which are lowCpcoeffs and highCpcoeff.
For example : janaf_.lowCpcoeffs()
When I compile my code, I have no errors, but when I run the code I have a bas cast error ( std::bad_cast)
I don't know how to solve this problem,. If you have any idea you're welcomed.
thanks
sebastien
sebastien_F1 is offline   Reply With Quote
janaf, openfoam, polynomial, thermo
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 12:26
A way to optimize the WENO scheme by optimizing the coefficients of linear scheme moon_light Main CFD Forum 1 November 27, 2012 10:19
calling Janaf coeff sebastien_F1 OpenFOAM Running, Solving & CFD 0 August 13, 2012 16:20
Blottner Coefficients f_sizer Main CFD Forum 0 August 26, 2010 08:03
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 05:07
