June 28, 2019, 01:37 |
#41 |
Rep Power: 7 |
Hello Everyone,
I am new to OpenFoam. Based on the solver posted in this thread, I have combined electrical equations with buoyantBoussinesqPimpleFoam. My intention is to have a solver for single phase EHD flow. I am able to compile the solver successfully. Could some one please suggest me a good benchmark case to validate the solver. Thank You. With Thanks. Pavithra. Last edited by Pavithra; June 28, 2019 at 01:38. Reason: adjust spacing |
June 28, 2019, 10:39 |
#42 |
Nicolao
Rep Power: 14 |
Dear Pavithra,
I guess you probably already seen this paper (from Herrera), http://gfs.sourceforge.net/papers/ehd.pdf but in there they show several validation cases for each equation of the leaky dielectric model (for EHD flows). Of course they use a two-phase approach, but for the Poisson and the charge conservation equations you can use the same cases they used there. "My intention is to have a solver for single phase EHD flow" Now, specifically for your case I guess you already have something in mind. =) Cheers |
June 28, 2019, 10:47 |
#43 | |
Nicolao
Rep Power: 14 |
In the work of Roghair you can also see some validation tests. I'm not quite sure, but I guess those are similar to the ones used by Herrera. He also included some MultiRegion validation that he used specifically for his work. https://link.springer.com/article/10...404-015-1581-5 |
June 29, 2019, 01:12 |
#44 | |
Rep Power: 7 |
Dear Sir, Thank you so much for your kind reply. I will read the research papers which you have shared. https://www.sciencedirect.com/scienc...04388615000030 I have tried to validate the solver with respect to the above article. I am trying to replicate the velocity profile presented in Fig 7 of the above paper. I am able to see electroconvection of charge. I am able to obtain a velocity profile of the same shape. But, the magnitude is 10^-10 smaller. One possible reason might be some mistake in non-dimensional parameters. I have cross-checked it several times. I am stuck at this point. Thank You. With Thanks, Pavithra. |
September 22, 2019, 09:53 |
#45 | |
Golden
Rep Power: 7 |
Dear Ivo, I am so excited to know that you once prepared to share your code and your cases. I am doing some work with two phase electrohydrodynamics with VOF model recently but I met some problems. I try to download the code but it seems that the URL is now unavailable. Would you mind to upload your code again in other ways? I'll be very grateful for any reply from you. Best regards, Golden |
September 23, 2019, 02:23 |
#46 | |
Rep Power: 7 |
Hi Cloud Bird, Please find the files of InterEHDFoam attached, herewith. |
October 22, 2019, 10:04 |
water impact surface under electrical field
#47 |
XinZhou
Rep Power: 8 |
Hello,everyone. I am simulating a water droplet impact surface under electrical field based on the interFoamEHD solver which designed by ivook.My model is 2D-Axisymmetric. I find that the charge density distribution is weird, there is some charge appearing above the droplet along the axis. I am puzzled by this problem. The charge density distribution is related to the velocity Magnitude.
I think the charge conversation equation is calculated for all computation field,both water and air in the interFoam solver. However, for water, it will get polarized and ohmic migration of charged ions. For air,it can be regarded as a perfect dielectric, there is no charge convection. I think we should use different physical model for water and air. But can it be realized in interfoam. I am comfused by the interfoam solver. How does this sovler distinguish the phase1 and phase2? I am reading the twoPhaseMixture.H, incompressibleTwoPhaseMiture.H ,but still get stuck.Could you please give me some advices? charge distribution 2.png charge distribution.png equation.jpg |
January 8, 2020, 14:37 |
#48 |
X
Rep Power: 7 |
Firstly, thank you for the solver. I am trying to update the solver on OF6. However, the droplet breakup is significantly different to the original solver. I have uploaded my solver on Google Drive due to exceeding file size [1]. Could someone point out where exactly am I going wrong in terms of modifying my solver. I have attached the screenshot for the last time step with OF231 and OF6. OF231 last_OF231.png OF6 last_OF6.jpg [1] https://drive.google.com/open?id=1Jd...KiYCL0Wc3JHxyi |
February 23, 2020, 18:11 |
intermhdfoam vs interehdfoam for lorentz force in arc welding scenarios
#49 |
Thomas Flint
Rep Power: 10 |
Hi All,
Thanks for sharing the code. I hope this is an appropriate thread to ask my questions as they are a bit more general than the electrohydrodynamics solver discussed here, and I think its more of a magnetohydrodynamics question really, but I was wondering if this thread was relevant to my problem. Basically I currently have a VOF solver fro simulating multi-component metallic melting and vapourisation, with energy equations, source terms in the NS equations for solidification etc. I use this to simulate power beam welding applications and arc welding applications, but I would really like to incorporate the electric charge transport and magnetic effects to look at the effect of the Lorentz force on the molten pool behaviour. I have a mhd + interfoam solver that I constructed based on this work: https://www.researchgate.net/publica...etallic_liquid As I understand it I could either use an mhd approach or an ehd approach, and I was wondering if people had any thoughts on which may be appropriate. Are the source terms in the NS equations in the interehdfoam solver equivalent to the JxB lorentz force term in the mhd (and my intermhdfoam solver)?? But I would like to be able to apply a alternating electric potential as a boundary condition. Would you guys have any pointers on the best way for me to progress? I could work out the time varying B field using Amperes law based on an alternating current density (I think), and put this as my B boundary condition in my mhd+interfoam solver. But I thought I'd try and get some advice from people more experienced than me before I go down this route to try and save myself some time in the long run. Thanks in advance for any advice you guys can offer. I'm very grateful. All the best, Tom |
November 18, 2020, 07:52 |
Updated link to source
#50 |
Ivo
Rep Power: 14 |
I shared my code a while back, but the link seems to stop working every now and then. So I did what I should have done a long time ago, create a github repository. You can find it here (but still based on OF2.1.1): https://github.com/iroghair/openFoamEHD
Although I am not focussing my research on EHD specifically at this time, I welcome pull/merge requests; a few people in this thread already took the source and updated it, I would be happy to update any updates or other changes to help other users. |
November 18, 2020, 08:05 |
#51 | |
Nicolao
Rep Power: 14 |
Hello Ivo, how are? Just making an observation here: I've worked a lot with your solver and with some adaptations I've made to it. I can surely affirm here, that it can be easily compiled/adapted to any other version of OpenFOAM. I've compiled it on the most recent versions as a test, and it works just fine. I'm glad you added a github repository. Cheers to all |
January 7, 2021, 13:20 |
#52 |
Hi Nicolao,
could you please share your adapted most updated version of openFoamEHD? It would be very usefull to compare the results with the original version. Thanks |
January 7, 2021, 14:51 |
Solver OF1812
#53 | |
Nicolao
Rep Power: 14 |
Hi Marco, the last version of OpenFOAM I've tested was the OF1812 I attached here this adapted version. I haven't checked the numerical results, but qualitatively it seemed alright for me. Hope it works well with you. Cheers |
February 27, 2021, 19:30 |
#54 |
Rep Power: 5 |
Hey Nicolao, many thanks for providing your updated version of the EHD solver.
When I try to compile the solver, I get a few errors that seem to be related to CorrectPhi.H. I'm very new with openFoam so I'm not sure what I'm doing wrong eactly. I would appreciate if you could provide any help. Thanks! |
March 1, 2021, 20:51 |
#55 | |
Nicolao
Rep Power: 14 |
can you share the error message and tell me what version of OpenFOAM are you trying to compile it? Best |
March 2, 2021, 08:27 |
#56 |
Rep Power: 5 |
Hey Nicolao,
I managed to solve the problem, thanks for offering help though! I was wondering if you have by any chance any cases that I could use to test my solver. I tried using the original cases provided by Ivooo but they don't seem to be working. I am using OpenFOAM 1812 and using the files you attached in a previous post here (of1812.zip). Many thanks! |
April 13, 2021, 16:10 |
EHD test case
#57 | |
Nicolao
Rep Power: 14 |
Sorry for the late response. Things are kinda crazy around here... I am attaching here a case that I think it can work for you (or anyone else interested). Its an axisymmetric droplet subjected to an electric field - the classic case that you can find on my paper: https://www.sciencedirect.com/scienc...77025714001426 I am not sure thou about what kind of conditions I used here, but you can use any other condition you like that the case will probably work just fine. Hope it helps you out. Cheers |
May 21, 2021, 08:31 |
#58 |
Haipeng Yang
Thank you very much for sharing. I successfully compiled your solver, but when I verified the droplet deformation in the electric field, I could only observe the long deformation of the droplet. I hope you can answer my question.
May 9, 2022, 14:25 |
EHD foam latest version
#59 |
ghanashyam k c
Rep Power: 4 |
If someone has the latest version of this solver could you upload it here? It will be much helpful for me... I'm kind of in an urgency
August 3, 2022, 00:50 |
interFoamEHDMR prolem
#60 |
chi thuc
Rep Power: 4 |
Hi Ivoo and you guys, Thank for your upload file code on GitHub. Im totally newbie in CFD, I download interFoamEHD and interFoamEHDMR solver one month ago to try simulate some cases like paper of Ivoo. I complied both of solvers without prolems and can simulate the cases related to interFoamEHD solver. ' I use OpenFoam2.1.1, Ubuntu18.04.5, Window 10 '
However, i facing prolem like this, 1. When i try run solver inteFoamEHDMR for case case ' dielectric-dielectric_Multiregion ' . The error ' can not upload groovyBC ' and ' can not upload libcoxvoinov.so ' appeared on terminal. So how can I fix this prolem 2. I try to run blockMesh of case ' dielectric-dielectric_Multiregion ', but in the polymesh folder have two diffrent file blockMeshDict and blockMeshDict.bak with different geometry. So, how can I run blockMesh to get full geometry multi region solid-fluid-fluid like paper. I hope will receive your help soon. I really appreciate for you help. Thank you guys so much. |
