Real Gas EOS
Like Tree7Likes
Old   September 23, 2013, 02:37
Aaron
dalaron is on a distinguished road
I downloaded Chris's of_realFluid from github, but do not know how to compile this on my machine. My experience is limited to making simple modifications to solvers and just using wmake. I'm not sure what I should be doing to ensure the thermophysical property modifications are also included.
dalaron is offline   Reply With Quote
Old   September 23, 2013, 04:23
Christian Lucas
Chris Lucas is on a distinguished road
you downloaded OpenFOAM 2.1 with my modifications. Simply compile the code (as you would compile the "normal" OpenFOAM version). The water properties (external media) must be compiled by hand (not included in script)
Christian
Chris Lucas is offline   Reply With Quote
Old   September 23, 2013, 06:20
Peter Bishop
PeterBishop is on a distinguished road
Hi Chris,
I added the following lines to createfields.H, compiled the solver correctly but when I try to run the realFluidPISOSolver, it is not able to write the Cp field.
    volScalarField Cp
        IOobject
            "Cp",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        thermo.Cp()
I tried also to add this in realFluidPISOSolver.C with no success
        rho = thermo.rho();
        Cp  = themro.Cp();
        runTime.write();
PeterBishop is offline   Reply With Quote
Old   September 23, 2013, 06:48
Christian Lucas
1. in here is a typo
rho = thermo.rho(); Cp = themro.Cp(); runTime.write();
is this correct im code?
2. Please try
volScalarField Cp2 ( IOobject ( "Cp2", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), thermo.Cp() );
3. Add an Info line in the Cp() function of realgasThermo.C to see if the function is called.
Christian
Old   September 23, 2013, 06:55
Aaron
Thanks for the response Chris. I'm still very new to this, so my apologies if these are very basic questions.
As a test I tried the Allmake shell script for my openfoam211 install (not the of_realFluid) to see how it works, but got a whole bunch of error messages.
I moved into /opt/openfoam211 and executed Allmake by
./Allmake
That was giving me a lot of errors. For example.
make[1]: *** [multiphaseInterFoam] Error 1
mkdir: cannot create directory `linuxGccDPOpt': Permission denied
Tried running this with sudo/password in an attempt to fix the Permission denied message, but that didn't work either.
aaron:/opt/openfoam211$ sudo ./Allwmake
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
    The environment variables are inconsistent with the installation.
    Check the OpenFOAM entries in your dot-files and source them.
aaron:/opt/openfoam211$ cd $WM_PROJECT_DIR
I'm in the right directory so I'm not quite sure what's going on.
The (limited) experience I have compiling with OpenFOAM requires a Make folder, and files + options with that Make folder. Compiling everything else as you are suggesting isn't like that (at least I don't think so) so I'm getting confused. I've also tried the Allmake shell script in src folder, but get similar error messages
Old   September 23, 2013, 07:57
Christian Lucas
you are trying to compile OF under root without being a superuser.
Have a look through the forum you will definitely find some theads about how to compile OF
Christian
Old   September 23, 2013, 09:53
Peter Bishop
Hi Chris,
Yes, the code is ok.
2. Please try
In this way the solver is able to write the specific heat field, every time step the Cp2 variable is written, but I'm not sure to understand why the code does not accept Cp.
Thank you very much for your kind support!
Old   September 23, 2013, 09:56
Christian Lucas
the problem is that in realGasHThermo, a field called Cp is constructed in the Cp() function. So you have to fields with the same name and the last field (which is the one in realGasHThermo) is used.
Christian
Old   September 23, 2013, 11:20
Aaron
I may be missing something obvious, but when attempting to compile realFluidPISOSolver I get the following error message.
In file included from realFluidPISOSolver.C:45:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:12:43: error: ‘class Foam::basicPsiThermo’ has no member named ‘drhodh’
in createFields.H, line 45
const volScalarField& drhodh = thermo.drhodh();
I do not know how to compile thermophysical properties which I think needs to be done? Executing Allwmake in of_realFluid/src/thermophysicalModels gives some permission errors and I haven't been able to figure out why.
Thanks for your for your patience. I am learning (albeit slowly!)
Old   September 23, 2013, 11:27
Christian Lucas
you have not compiled my thermo code, so the solver calls a function unknown to him.
Christian
Old   September 23, 2013, 12:39
Aaron
Christian
I don't know how to do that. I've looked around online and in the user guide and still am not sure. There is a similar thread here (http://www.cfd-online.com/Forums/ope...erties-ii.html) and my understanding is that I need to modify Make/options to include the correct path. Something kind of like:
EXE_INC = \
    -I$(WM_PROJECT_USER_DIR)/of_realFluid/src/thermophysicalModels/specie/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/of_realFluid/src/thermophysicalModels/basic/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/of_realFluid/src/turbulenceModels/compressible/turbulenceModel \
    -I$(WM_PROJECT_USER_DIR)/of_realFluid/src/finiteVolume/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lbasicThermophysicalModels \
    -lspecie \
    -lcompressibleTurbulenceModel \
    -lcompressibleRASModels \
    -lcompressibleLESModels
Is this even remotely close to what I should be doing?
Can you possibly provide a more detailed description of how to compile everything correctly?
Old   September 25, 2013, 12:11
Peter Bishop
Hi Chris,
I'm using realFluidPISOSolver to simulate transcritical injenction of Nitrogen according to the article below with very good result. In the attached image the experimental data for axial density are compared to the simulation results.
The solver seems to work correctly and it is very reliable!
Tae Seon Park, LES and RANS simulations of cryogenic liquid nitrogen jets, J. Of Superciritical Fluids 72 (2012) 232-247
Since you coded real gas formulation for mixtures also I'm wondering how difficult would be to link your library to reactingFoam solver.
Regards
Old   September 26, 2013, 08:45
Christian Lucas
HI,
depends on your goal. If you simply want to mix inert gases, that should be easy.
Christian
Old   September 28, 2013, 09:00
Aaron
Hi Chris,
Sorry to continue bothering you with this, but I am still not able to compile your real gas solver on my computer. I really want to get this working and haven't been able to figure out my problems over the last few days.
Peter, perhaps you can help me out also?
Chris, you mentioned that I need to compile the thermo code. I haven't been able to do that. I have the of_realFluid from your git saved to my home folder:
 aaron:~/OpenFOAM/aaron-2.1.1/of_realFluid/
To try and compile the thermo code I moved into
 aaron:~/OpenFOAM/aaron-2.1.1/of_realFluid/src/thermophysicalModels/basic$
and executed wmake command. I get the following error message:
In file included from mixtures/basicMixture/basicMixture.C:26:0:
mixtures/basicMixture/basicMixture.H:39:23: fatal error: volFields.H: No such file or directory
compilation terminated.
make: *** [Make/linuxGccDPOpt/basicMixture.o] Error 1
So it can't find volFields.H.
Within the Make folder, I changed "files" at the very end to have LIB = $(FOAM_USER_LIBBIN)/libbasicThermophysicalModels and this is my "options" file:
EXE_INC = \
    -I$(WM_PROJECT_USER_DIR)/of_realFluid/src/finiteVolume/lnInclude \
LIB_LIBS = \
    -lfiniteVolume
I have tried looking around the forums for a few days now and don't know what to do. Any help is much appreciated.
Regards,
Aaron
Old   September 30, 2013, 05:14
Christian Lucas
change the installation path in OpenFOAM/etc/bashrc and compile OpenFOAM (all of it) using Allwmake (the installed OF version must not be loaded)
or
compile the thermo library as a FOAM_USER_LIBBIN. Rename it dynamic library (e.g. /libbasicThermophysicalModels2). Make sure the install OpenFOAM version on your machine is compatible to the OF version I used. The environment variables of the installed OF version must be loaded. Then, change the path to the new thermo library in the solver and compile the solver
Christian
PS:
have a look at
http://openfoamwiki.net/index.php/In...OpenFOAM-2.1.1
or
http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu
Old   October 1, 2013, 12:14
Peter Bishop
Hi Chris,
mixing inert gases should be a good starting point! My real goal is to have a real gas capable version of reactingFoam.
Old   October 2, 2013, 03:48
Christian Lucas
the library can mix inert gases if you provide the correct mixture class (e.g. rewrite pureMixture.C).
For reactions: A guess you need to add a few more things. Have a look at the difference between specieThermo and realGasSpecieThermo (especially the functions I remove without an equivalent new function)
Another point is the enthalpy of formation, which must be included.
Finally, you must add the library to the reaction models (have a look how the current thermo models are connected to the reaction model)
Christian
Old   December 2, 2013, 11:41
Default Problem with IAPWS package
  #38
magazoni
magazoni is on a distinguished road
Hi Chris,
The real gas package is working, but when I tried to use the IAPWS package, the following error appears:
--> FOAM FATAL ERROR:
Unknown basicPsiThermo type IAPWSThermo
Valid basicPsiThermo types are:
35
ePsiThermo<pureMixture<constTransport<specieThermo<eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieThermo<eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>>
hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>>
realGasEThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<aungierRedlichKwong>>>>>
realGasEThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<pengRobinson>>>>>
realGasEThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<redlichKwong>>>>>
realGasEThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<soaveRedlichKwong>>>>>
realGasEThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<aungierRedlichKwong>>>>>
realGasEThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<pengRobinson>>>>>
realGasEThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<redlichKwong>>>>>
realGasEThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<soaveRedlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<constantHeatCapacity<aungierRedlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<constantHeatCapacity<pengRobinson>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<constantHeatCapacity<redlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<constantHeatCapacity<soaveRedlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<aungierRedlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<pengRobinson>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<redlichKwong>>>>>
realGasHThermo<pureMixture<constTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<soaveRedlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<constantHeatCapacity<aungierRedlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<constantHeatCapacity<pengRobinson>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<constantHeatCapacity<redlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<constantHeatCapacity<soaveRedlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<aungierRedlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<pengRobinson>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<redlichKwong>>>>>
realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<soaveRedlichKwong>>>>>
    From function basicPsiThermo::New(const fvMesh&)
    in file psiThermo/basicPsiThermo/basicPsiThermoNew.C at line 60.
FOAM exiting
I tried to compile the IAPWS package, but there is a problem,
cluster@node0:/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/externalMedia/IAPWS_Waterproperties$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file IAPWSThermo/IAPWS-IF97.C
Making dependency list for source file IAPWSThermo/IAPWSThermos.C
SOURCE=IAPWSThermo/IAPWS-IF97.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude  -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/IAPWS-IF97.o
In file included from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.H:360:0,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/DimensionedField.H:42,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricField.H:44,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/volFields.H:37,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude/basicThermo.H:39,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude/basicPsiThermo.H:39,
                 from IAPWSThermo/IAPWS-IF97.H:44,
                 from IAPWSThermo/IAPWS-IF97.C:33:
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C: In member function ‘void Foam::Field<Type>::operator=(const Foam::VectorSpace<Form, Cmpt, nCmpt>&)’:
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C:680:42: warning: typedef ‘VSType’ locally defined but not used [-Wunused-local-typedefs]
     typedef VectorSpace<Form,Cmpt,nCmpt> VSType;
IAPWSThermo/IAPWS-IF97.C: In function ‘void Foam::calculateProperties_h(SteamState, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&, Foam::scalar&)’:
IAPWSThermo/IAPWS-IF97.C:240:62: warning: variable ‘cpv’ set but not used [-Wunused-but-set-variable]
         scalar rhov,rhol,betav,betal,kappav,kappal,vv,vl,cpl,cpv,hl,hv,cp;
IAPWSThermo/IAPWS-IF97.C: In function ‘Foam::scalar Foam::psiH(SteamState)’:
IAPWSThermo/IAPWS-IF97.C:432:62: warning: variable ‘cpv’ set but not used [-Wunused-but-set-variable]
         scalar rhov,rhol,betav,betal,kappav,kappal,vv,vl,cpl,cpv,hl,hv,h,p;
IAPWSThermo/IAPWS-IF97.C:489:12: warning: ‘psiH’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     return psiH;
IAPWSThermo/IAPWS-IF97.C: In function ‘Foam::scalar Foam::drhodh(SteamState)’:
IAPWSThermo/IAPWS-IF97.C:586:12: warning: ‘drhodh’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     return drhodh;
SOURCE=IAPWSThermo/IAPWSThermos.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude  -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/IAPWSThermos.o
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude/makeBasicPsiThermo.H:35,
                 from IAPWSThermo/IAPWSThermos.C:34:
In file included from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/typeInfo.H:57:0,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/IOobject.H:76,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/regIOobject.H:41,
                 from /opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/GeometricField.H:42,
IAPWSThermo/IAPWSThermos.C: At global scope:
IAPWSThermo/IAPWSThermos.C:65:5: error: ‘Foam::IAPWSThermo::typeName’ is not a static data member of a class template [-fpermissive]
     IAPWSThermo
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/className.H:102:24: note: in definition of macro ‘defineTypeNameWithName’
     const ::Foam::word Type::typeName(Name)
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/className.H:202:5: note: in expansion of macro ‘defineTemplateTypeNameWithName’
     defineTemplateTypeNameWithName(Type, Name);                               \
/opt/OpenFOAM/OpenFOAM-2.1.0/src/thermophysicalModels/basic/lnInclude/makeBasicPsiThermo.H:100:1: note: in expansion of macro ‘defineTemplateTypeNameAndDebugWithName’
 defineTemplateTypeNameAndDebugWithName                                        \
IAPWSThermo/IAPWSThermos.C:63:1: note: in expansion of macro ‘makeBasicExternalLibraryBasedThermo’
IAPWSThermo/IAPWSThermos.C:65:5: error: ‘Foam::IAPWSThermo::debug’ is not a static data member of a class template [-fpermissive]
     IAPWSThermo
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/className.H:143:9: note: in definition of macro ‘defineDebugSwitchWithName’
     int Type::debug(::Foam::debug::debugSwitch(Name, DebugSwitch))
/opt/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/className.H:203:5: note: in expansion of macro ‘defineTemplateDebugSwitchWithName’
     defineTemplateDebugSwitchWithName(Type, Name, DebugSwitch)
make: ** [Make/linux64GccDPOpt/IAPWSThermos.o] Erro 1
Do you have any idea about this?
Thanks in advanced,
Felipe Magazoni
magazoni is offline   Reply With Quote
Old   December 2, 2013, 12:14
Christian Lucas
do you use my github code or have you included the new code in your OF version?
Christian
Old   December 2, 2013, 12:19
Christian Lucas
the problem seems to be related to the macro in basicPsiThermo.
Have a look if the code is copied correctly.
Christian
high pressure injection, openfoam 2.1.x, real gas
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
error message cuteapathy CFX 14 March 20, 2012 07:45
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
