dynamicRefineFvMesh with mesh deformation
Old   May 31, 2012, 18:15
Default dynamicRefineFvMesh with mesh deformation
boeleman is on a distinguished road
I am trying to set up a simulation where I combine mesh deformation with mesh refinement, but I cannot get it to work, and I'm wondering whether anyone could help.
I made a local copy of the dynamicRefineFvMesh and added the following code at the beginning of the update routine, which should give the result that my simulation box is stretched periodically in the z direction:
// Grid stretching and compression
scalar oldTime = time().value() - time().deltaT().value();
scalar Time = time().value();
// Height of the cube at the old time
scalar oldZ = startZ_ + amplitude_*(
::sin(constant::mathematical::twoPi*frequency_*old Time)
// Height of the cube at the new time
scalar Z = startZ_ + amplitude_*(
::sin(constant::mathematical::twoPi*frequency_* Time)
Info<< "Mesh scaling. Time = " << time().value() << " Box height = "
<< Z << endl;
pointField newPoints = points();
// Calculate where a grid point was relative to oldZ and multiply with Z to have
// the same new relative position
newPoints.replace
vector::Z,
points().component(vector::Z)*Z/oldZ
// fvMesh::movePoints(newPoints);
However, I get an error message:
Cannot find surfaceScalarField meshPhi in user-provided flux mapping table
and the code crashes with a floating point exception after a couple of iterations.
Thanks,
Arnout
boeleman is offline   Reply With Quote
deformation, dynamicrefinefvmesh, interdymfoam, meshphi
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
