Khurram
Rep Power: 16 ![]() |
I am trying to introduce a new drag model in compressibleTwoPhaseEulerFoam solver but on executing the "wmake libso" command i get following error. "No rule to make target 'dragModels/Mydragmodel/Mydragmodel.dep' , needed by 'Make/linuxGccDPOpt/dependencies' . Stop." Please help me in this.... Thanks.. |
Kyle Mooney
Rep Power: 18 ![]() |
Have you tried running 'wclean' first? Also, what does the 'Make/files' contain?
Khurram
Yes, i have tried running wclean first but of no use. The Make/files within the "interfacialModles" contains the declaration of different heat transfer and drag models which can be used. I have added the declaration for my drag model in it.
wided
sometimes you need to check if the *.C file has the same name as you gave your executable in the "file" document.
Good luck |
Disabled
Rep Power: 15 ![]() |
Sometimes you may also need to use a "make*" command in order to add your model to the tables containing the list of available models (I think these are called the runtime tables or something similar. But I could be very wrong).
For example, I frequently use the dsmcFoam solver. There exist various models for the inflow of molecules. If I want to make a new one, I should not only copy the directory closest to my case but I should add an entry in Code:
src/lagrangian/dsmc/parcels/derived/dsmcParcel/makeDsmcParcelInflowBoundaryModels.C The easiest way to find what you need to do is to grep for an existing model. E.g. if there was a "previousModel" you can just go to the main directory and type Code:
grep -r previousModel ./ EDIT: Cool, I just realised this was a rather old post. Anyway, I hope someone will find it useful. |
dependencies, drag, openfoam 2.1.0 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
drag calculation of a car model by phoenics | mukut | Phoenics | 2 | January 9, 2010 18:07 |
multiphase model and drag law | Yasmail AKARIOUH | FLUENT | 0 | April 29, 2008 07:44 |
multiphase flow modelling, Drag model | Anant | CFX | 1 | February 4, 2008 04:18 |
Laminar wing profiles and drag | gregorv | OpenFOAM Running, Solving & CFD | 4 | December 4, 2007 13:25 |
