New BoundaryCondition: how to modify a single component of a field?
Old   April 26, 2012, 14:35
Default New BoundaryCondition: how to modify a single component of a field?
Lucio Cardillo
look86 is on a distinguished road
hello,
I need to make for a simulation a new type of boundary condition. This is my first attempt of programming with openFoam and I'm able to realize a time varying boundary condition starting from oscillatingFixedValueFvPatchField file.
As in oscillatingBC the field varies with time and it is great for a single component field, such as the pressure p. But if I want to vary only a single component of a velocity field for example, I didn't understand how I can do that. I Understood that the field class belongs from List class, and so I tried with a for cycle and edit one by one all the elements of the list (field), but if I try to reach the x() y() or z() method of the single element I get an error because only the vector class have these method..
so how I can reach this method and vary single component of element of the field list?
best regards and sorry for my bad english
Lucio
look86 is offline   Reply With Quote
Old   April 26, 2012, 14:50
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi Lucio
All BCs in OF are templated, which means they work for scalars, vectors and tensors in the same fashion. If you elaborate more on your problem, maybe you'll receive better answers!
The cyclic BC will apply the same calculation to all elements of your variable (e.g. a Vector).
If you need to make a BC that works only for one component of a vector, you may consider using codedFixedValue, groovyBC or change the patch from inside the solver.
Regards,
Hisham
Hisham is offline   Reply With Quote
Old   April 27, 2012, 13:00
Lucio Cardillo
thank you very much for the reply! However I reach up a solution with this function in my new BC timeVaryingVelocityComponent
template<class Type>
Field<Type> timeVaryingVelocityComponentFvPatchField<Type>::modRefValue()
        Field<Type> copy_(refValue_);
        List<scalar> l_(refValue_.size());
        direction d(component_);
        List< typename Field<Type>::cmptType> Comp_(copy_.component(d));
        label k(searchMax());
        for (label i=0; i<l_.size(); i++)
                l_[i]=Comp_[i]*currentScale(Comp_[k]);
        copy_.replace(d,l_);
        return copy_;
In this code I modified only the single component (indicated by the int value component_) and I leave untouched the other..
and finally the function searchMax that give the index of the field that points to biggest value between the single component field:
template <class Type>
label   timeVaryingVelocityComponentFvPatchField<Type>::searchMax()
        label maxIndex(0);
        List< typename Field<Type>::cmptType > Comp_refValue_.component(d));
        for (label i=0; i<refValue_.size(); i++)
                if (Comp_[i]>=Comp_[maxIndex]) maxIndex=i;
        return maxIndex;
I'm sure, It's nor the best neither the more elegant solution, but It works and for uniform and nonuniform velocity field!
critiques & suggestions are always welcome
Best regards,
Lucio
Old   April 28, 2012, 11:22
Lucio Cardillo
Hello!
I don't know why, but for parallel application this construct works fine:
        return copy_;
but this other gives me always Fatal error from first iteration!
//************modified part************************\\
        scalar curr_(currentScale(Comp_[k]));
//****************modified part**********************\\
                l_[i]=Comp_[i]*curr_;
        return copy_;
this error occurs only in parallel process (mpirun -np 4 "solver" -parallel) but if I remove the option -parallel it works fine (but not in parallel I suppose ). Indeed the second way is more efficient because I don't call the function currentScale() every step of the loop!
can anybody give me some explanation?
Regard,
Lucio
Old   August 28, 2012, 17:48
Olivier Rouch
roucho is on a distinguished road
Send a message via MSN to roucho
Standard C++ notes:
1- Make sure that the "currentScale(...)" you invoke returns a scalar
2- Try the parallelized "forAll(...,...)" instead of the classic "for(i=0;...;i++)"
roucho is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Tangential component of gradient of scalar field at surface tehache OpenFOAM Running, Solving & CFD 5 July 4, 2013 08:13
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 08:37
