interFoam and alphaEqn.H
Old   April 25, 2012, 05:50
Default interFoam and alphaEqn.H
Pablo
pablodecastillo is on a distinguished road
Why in alphaEqn.H is it not added alpha1 = max(min(alpha1, scalar(1)), scalar(0)); i mean this artificial bounded?
Thanks
pablodecastillo is offline   Reply With Quote
Old   April 25, 2012, 06:55
Pablo Higuera
Phicau is on a distinguished road
Hi
MULES solver ensures boundedness, that is why the last 2 inputs are 0 and 1, the bounds of alpha1. This is achieved by the use of limiters.
The final result may show values greater than 1 or lower than 0, but with differences of the order of 10^-5, which is negligible.
Regards
Phicau is offline   Reply With Quote
Old   May 1, 2012, 09:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Using an artificial bounding of this kinds leads to a non-phase-preserving algorithm due it 'cuts' with having in account the conservative properties of the alpha equation. In other words you will lose or gain mass.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 7, 2012, 14:57
Pablo
But looking for steady state loss or gain mass is not going to be relevant or yes?
Thanks
Old   May 8, 2012, 13:59
Hhmm, I don't know, but since the solver is unsteady probably it will blow up before reach the steady state due mass preservation problems.
Regards.
Research Scientist
Old   March 28, 2016, 11:47
Saideep
Saideep is on a distinguished road
Hi guys,
I guess this is the most relevant thread I found to post the following question and hope anyone of you could help me out.
The alphaEqn.H file has evolved from 2.2 version to 2.3 version. I can understand the 2.2 version of the code but I cant follow most part of the 2.3 version of alphaEqn. Can you help me out?
What does the following code indicate?
fvScalarMatrix alpha1Eqn
fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
+ fv::gaussConvectionScheme<scalar>
mesh,
phi,
upwind<scalar>(mesh, phi)
).fvmDiv(phi, alpha1)
The later part is from the older version for advection of alpha with velocity and relative velocity terms.
I tried to use the older version into this but alpha is no more bounded between 0 and 1.
Thanks;
Saideep
Saideep is offline   Reply With Quote
Old   April 16, 2016, 22:00
Hi Saideep, the new version of alphaEqn is based on operator splitting techniques to obtain a semi-implicit solver. The code you posted corresponds to the first-order bounded predictor of alpha which is lately corrected by a high-order corrector:
http://www.openfoam.org/version2.3.0/multiphase.php
Regards.
Research Scientist
compressibilty effect in alphaEqn.H nimasam OpenFOAM 21 February 20, 2018 17:30
Small time step in interFoam Andrea_85 OpenFOAM 35 October 31, 2017 23:14
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Vof method in interFoam Andrea_85 OpenFOAM 10 February 17, 2011 05:41
