flux through fan duct
Old   April 24, 2012, 11:26
Default flux through fan duct
Andreas Zürner
Anderl is on a distinguished road
I'm using actuator disks to simulate fans. My problem is now that I would like to get the flux through the fan during the calculation in order to change the forces of the actuator disk so to say "on the fly". For the moment I have an inlet (red surface in the image) and outlet, so it would be easy to calculate the flux from these boundaries, but later the fan will be situated in a closed room and then I do not have any more this possibility.
So, I think about using cuttingPlane to cut through the middle of the duct (perpendicular to the flow direction) and from U and the face areas of the triangles the calculation of the flux should be possible. sampling seems to work (sampleDict is attached), but how can I implement this in my solver (the simpleFoam solver modified to be able to use actuator disks; it's also attached)?
I already managed to get at each iteration step a new time folder in the surfaces directory containing the vectorfield data of U and the faceCentres, faces and points of the sampled surface (cuttingPlane through the fan duct).
But how can I tell OpenFOAM to read this data? Or even better, is there a possibility to implement the cuttingPlane and the flux calculation without writing timefolders in the surfaces folder?
I'm sure there's a simple solution for my problem and I would really appreciate any help.
Anderl is offline   Reply With Quote
cuttingplane, flux calculation, read data, sampling
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Inlet shapes for modelling a fan in an inlet duct buzzybee CFX 10 June 11, 2009 21:15
Fluent 2D Model - Axial Fan in a Duct J FLUENT 0 April 18, 2006 03:25
Question about flow in ducted fan in another duct Jane FLUENT 0 June 21, 2004 14:57
flux momentum in a duct Roberto Ciardulli Siemens 0 October 26, 2000 11:56
