SnappyHexMesh
Old   February 16, 2012, 03:51
Default SnappyHexMesh
Anone
CFD_user_2012 is on a distinguished road
Hi all
I am a new user to OpenFoam. I am trying to simulate a building. I have a stl file in my constant/trisurface folder. I have a blockmesh in polymesh which I generated successfully. I them typed snappyHexMesh and everything is fine. Then I used paraFoam to view the building mesh. But I find that I can only see my blockMesh
I enclose my snappyhexmesh file with this message. Any help is much appreciated.
CFD_user
CFD_user_2012 is offline   Reply With Quote
Old   February 16, 2012, 10:53
Michael Ahlmann
danishdude is on a distinguished road
Snappy hex mesh exports the different phases of the meshing process into new time directories, so all you have to do is advance to the final time step to see your mesh. Alternatively, you can run snappy with the flat "-overWrite" so the mesh is exported in the constant/polyMesh directory instead.
danishdude is offline   Reply With Quote
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 17:02
[snappyHexMesh] snappyHexMesh simple help! atareen64 OpenFOAM Meshing & Mesh Conversion 0 March 2, 2011 16:52
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
[snappyHexMesh] SnappyHexMesh samiam1000 OpenFOAM Meshing & Mesh Conversion 0 October 5, 2009 11:32
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
