November 4, 2016, 14:59 |
#41 |
Maryam
Rep Power: 10 |
-n specifies the number of nodes.
-np specifies the number of processes. I cannot comment on your inquiry but I guess it should not matter which one (-n or -np) you use as long as you specify the same number of processes/nodes. |
March 3, 2020, 01:39 |
reconstructParMesh returns "no mesh" message.
#42 |
Prakriti
Rep Power: 8 |
Hi all,
I've been using blockMeshDict and thereafter snappyHexMeshDict for a given case to run in parallel. In the blockMeshDict, when my base hex resolution is (40 40 40), mesh decomposition works fine. However, when I increase this base resolution to (128 128 128), and run the case, blockMesh and snappyHexMesh create the mesh, decomposePar runs without returning any error messages, and the simulation starts. But when I run "reconstructParMesh", it gives me a "no mesh" error at EACH timestep. Has anyone encountered this odd error and if so, how is it to be navigated? |
March 3, 2020, 02:27 |
#43 |
Marco Müller
Rep Power: 13 |
Hi Praktiki,
there are many possible error sources in such a long process chain. Is there a specific reason why you are using reconstructParMesh? I've stopped using it because I also encountered problems with it. Also also remember that it is still some beta version?! For post processing in Paraview as far as I know you dont need it. Marco |
unchangeable continuity residuals in parallel computing | wlt_1985 | FLUENT | 0 | August 1, 2011 13:15 |
Diffusion equation solved using Parallel Computing | Sachin Paramane | Main CFD Forum | 0 | June 12, 2007 00:48 |
Parallel Computing on Multi-Core Processors | Upgrading Hardware | CFX | 6 | June 7, 2007 16:54 |
Parallel Computing | peter | Main CFD Forum | 7 | May 15, 2006 10:53 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
